[GRASS-dev] no addons metadata
The same problem as reported earlier is back it seems, no addons metadata available. This was a problem for 7.1 I think?
WARNING: Unable to parse
          'http://grass.osgeo.org/addons/grass7/modules.xml’: no element
          found: line 105, column 0
WARNING: No addons metadata available. Addons metadata file not updated.
Installation of <v.kriging> successfully finished
On Thu, Oct 1, 2015 at 10:42 AM, Paulo van Breugel <p.vanbreugel@gmail.com>
It seems like problem with generating the file on the server side. If you
visit the URL, you get:
XML Parsing Error: no element found
Location: https://grass.osgeo.org/addons/grass7/modules.xml
Line Number 105, Column 1:
grass-dev mailing list
grass-dev@lists.osgeo.org
2015-10-01 17:51 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
I checked modules.xml on build server, and it's OK. Strangely
modules.xml (which is copied from build server to osgeo server) is
broken. I fix it launching copying script manually.
@Markus: just to be sure aren't you not running any cronjob related to
addons on osgeo server?
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
