[GRASS-dev] No 'count' method for r.statistics
`r.statistics` which was/is meant for categorical raster maps, does not
provide for a 'count' method.
`r.stats.zonal`, on the other hand, which is meant for floating point
raster maps, does so.
This is rather unexpected. 'Count'ing pixels should rather derive 'CELL'
maps and not 'FCELL'.
At the moment, I require an extra mapcalc using the int() function.
Any comments?
Nikos
On Wed, Aug 1, 2018 at 11:59 AM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
r.statistics which was/is meant for categorical raster maps, does not
provide for a ‘count’ method.
r.stats.zonal, on the other hand, which is meant for floating point
This is rather unexpected. 'Count’ing pixels should rather derive ‘CELL’
maps and not ‘FCELL’.
Any comments?
Counting pixels can produce a result that is too large for CELL (32 bit integer), therefore storing the count as DCELL is a bit safer because it can exactly store integers larger than the 32 bit maximum.
In short, use r.stats.zonal rather than r.statistics.
Markus M
Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
* Markus Metz <markus.metz.giswork@gmail.com> [2018-08-01 20:33:33 +0200]:
Any comments?
Markus M
I understand it now.
If integrating this extra "int()" conversion, in `r.stats.zonal`, is not
a smart/wanted thing to do, maybe we should add an explanation in the
`r.statistics` manual. Why 'count' is missing and why `r.stats.zonal` should
be used.
I can offer a patch for the manual if you agree.
My guess is that the development team has future plans regarding all r.stat*
modules, to merge and simplify as much as possible.
Thank you Markus!
On Fri, Aug 3, 2018 at 10:13 AM Nikos Alexandris
>> Any comments?
>Markus M
be used.
No need to ask, it would be great :slight_smile:
Suggestions may be discussed here.
A related question from a (remote) colleague:
They have two Land Cover raster files at different resolutions, one at
5 m x 5 m and the other at 30m x 30 m with both 9 identical
categories.
They want to count the number of pixels of a category of the first map
that fall within each pixel of the second.
How to do that in an elegant way?
thanks
Hi Markus,
Not sure I fully understand the objective, but did you consider:
r.stats -c input=A_map,B_map
https://grass.osgeo.org/grass76/manuals/r.stats.html
(for overall counts)
or
https://grass.osgeo.org/grass76/manuals/r.resamp.stats.html
(for counts/diversity within each pixel).
Stefan
Fra: grass-dev grass-dev-bounces@lists.osgeo.org på vegne av Markus Neteler neteler@osgeo.org
Sendt: mandag 11. februar 2019 20.54
Til: Nikos Alexandris
Kopi: GRASS-GIS development mailing list
Emne: Re: [GRASS-dev] No ‘count’ method for r.statistics
nik@nikosalexandris.net wrote:
On Wed, Aug 1, 2018 at 11:59 AM, Nikos Alexandris nik@nikosalexandris.net
Any comments?
Markus M
If integrating this extra “int()” conversion, in r.stats.zonal, is not
r.statistics manual. Why ‘count’ is missing and why r.stats.zonal should
be used.
categories.
thanks
On Mon, Feb 11, 2019 at 9:17 PM Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
Hi Markus,
I agree, this seems to be the easiest way. The region and resolution should first be set to match the high-res raster.
Markus M
or
Stefan
Fra: grass-dev <grass-dev-bounces@lists.osgeo.org> på vegne av Markus Neteler <neteler@osgeo.org>
Any comments?
Markus M
be used.
categories.
thanks
Hi again,
Vero had a feature request in a similar direction for v.rast.stats (count / mode statistics) for categorical raster maps (e.g. land cover).
Should such a feature be added to v.rast.stats or would it make more sense to create a new module for that for not overloading v.rast stats.
I would have some code snippet in v.rast.bufferstats (https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.py#L506) that I could re-purpose…
What do you think?
Stefan
Fra: Markus Metz markus.metz.giswork@gmail.com
Sendt: mandag 11. februar 2019 21.19
Til: Stefan Blumentrath
Kopi: Markus Neteler; Nikos Alexandris; GRASS-GIS development mailing list
Hi Markus,
Markus M
or
Stefan
Any comments?
Markus M
be used.
categories.
thanks
On Mon, Feb 11, 2019 at 9:19 PM Markus Metz
Right, I didn't remember "-c" of r.stats.
Thanks Stefan and Markus, I have fwd'ed your suggestions.
(if something extra makes sense I cannot judge but I'll let you know
if the proposed way worked for them)
Best
markusN
