I cannot build grass programmer’s manual in PDF format from grass 6.4.0svn. only html manual is available in the online site.
http://download.osgeo.org/grass/grass6_progman_pdf/ .
anyone please post link/upload the pdf file if you have it.
Thanks in advance.
On Sun, Mar 7, 2010 at 8:23 AM, Mohammed Rashad <rashadkm@yahoo.com> wrote:
I cannot build grass programmer's manual in PDF format from grass 6.4.0svn.
Currently there is none - the problem is that the build process fails on the
GRASS server and I don't understand why.
Can you successfully build it on your local machine with
make pdfdocs
To: Mohammed Rashad rashadkm@yahoo.com
Cc: GRASS developers list grass-dev@lists.osgeo.org
Sent: Sun, March 7, 2010 5:59:13 PM
Subject: Re: [GRASS-dev] no grass 6 programmers manual in PDF
GRASS server and I don’t understand why.
make pdfdocs
make pdfdocs gives error
~/grass64_release/lib/db/latex$ make
rm -f *.ps *.dvi *.aux *.toc *.idx *.ind *.ilg *.log *.out refman.pdf
pdflatex refman.tex
This is pdfTeXk, Version 3.141592-1.40.3 (Web2C 7.5.6)
%&-line parsing enabled.
entering extended mode
(./refman.tex
LaTeX2e <2005/12/01>
Babel <v3.8h> and hyphenation patterns for english, usenglishmax, dumylang, noh
yphenation, loaded.
make: *** [refman.pdf] Error 1
if u can build on local system please upload on web
make pdfdocs
No, it fails for me.
pdflatex refman.tex
(./refman.tex
noh
yphenation, loaded.
Here we need to understand *why* it fails.
