So, this comes from the previous email, but it is a different issue…
I also got qgis stable (2.12) from osgeo4w 32bits installer and there seems to be NO grass plugin installed nor available in the plugin list.
There’s also NO grass tools in Processing and I have the latest version avilable. I guess I missed selecting some other things in the installation process, but don’t know what.
Did you go through the advanced install in OSGeo4W? There you should have the “qgis-grass-plugin7” (and probably also necessary “qgis-grass-plugin-common”) available.
Is OSGeoLive DVD/USB an alternative for you? That may help to avoid a lot of trouble (esp. when prepared and provided by you), caused e.g. by user names with non-ascii characters, missing-dlls access rights…
Stefan
Hi devs,
me again, sorry…
Did you install GRASS in OSGeo4W? Which version?
On Sunday I made an installation on Windows and I found a problem. GRASS 7.0.2RC is already available on OSGeo4W. However, the .bat file that is created for the use of GRASS7 with QGIS, does not work, because it points to the folder structure of GRASS 7.0.1.
I don’t know if this has been corrected since then, and whether this might be your problem. I am forwarding this thread also for QGIS mailing list.
Yes, i got grass stable (grass7.0.2RC) from OSGeo4W 32 bits
Ah! So, this might be (one of) the problem(s)… je!
Thanks much!
So, this comes from the previous email, but it is a different issue...
seems
There's also NO grass tools in Processing and I have the latest version
process, but don't know what.
Any instruction is welcome!
Vero
AFAIK grass plugin isn't installed by OSGeo4W default installation.
start the OSGeo4W-setup -> advanced install -> Libs:
Yeah, advanced install… Meep! I forgot some some essential clicks, maybe… ouch! Will try again and go back with news…
I thought of it, but for the time being i’ll try stick to local installation of grass and qgis ()… I’d want/like them to learn grass and then use/include it in their usual workflows… and not that they have to start a virtual machine and change OS to use grass… they may do that for some time but then, I feel they would drop it… Let’s see how it goes
Hi Pedro:
I’m not on the QGIS list, please forward to them that they would better use this approach to get the path rather than hardocing it:
grass70 --config path
If they need Python, they could use something like this:
So, i activated these libraries and now I get two different QGIS icons: one with grass6 and the other with grass7
The one with grass6 works fine, both grass plugin and grass tools through processing are there and seem to work
But, the one with grass7 does not have grass plugin installed nor in the available plugin list and, maybe because of that (?), grass tools through processing do not work and when trying to use any of them it opens a dialog box saying I need to configure grassgis7 folder… But there’s no GRASS item in Configuration → Options (maybe just because the grass plugin is not there), so I don’t know where or if i even can do that without the grass plugin… sorry for ignorant here
Thanks so much all of you for your help!
Best,
Vero
one
dialog
box saying I need to configure grassgis7 folder... But there's no GRASS
item in Configuration --> Options (maybe just because the grass plugin is
not there), so I don't know where or if i even can do that without the
grass plugin... sorry for ignorant here
Best,
Vero
opens a dialog box saying I need to configure grassgis7 folder... But
there's no GRASS item in Configuration --> Options (maybe just because
the grass plugin is not there), so I don't know where or if i even can
do that without the grass plugin... sorry for ignorant here
AFAIK, GRASS access via Processing does not depend on the grass plugin. However, you need to activate GRASS 7 in Processing->Options->Service providers->Grass 7.
Please, click in “Skip” and you should get 7.0.1-1. Click Next, install this version and then try again GRASS plugin in QGIS (search for GRASS 7 in Plugins → Manage and Install Plugins).
As Moritz said, Processing GRASS is independent from GRASS Plugin.
Yes! Thanks much, Moritz! Was searching in the wrong place (hihihi). This solved the issue with using grass tools through Processing.
Please, click in "Skip" and you should get 7.0.1-1. Click Next, install
Plugins -> Manage and Install Plugins).
I did that, and got GRASS 7.0.1-1...
Same issue, grass plugin still missing in the list
Yes, this works fine with both 7.0.1-1 and 7.0.2RC1-1
