[GRASS-dev] No GUI startup in GRASS 7
Nope neither one. Good idea, but it is something else.
I think what may have happened is due to recent work to make GRASS work with Windows because I can no longer run python scripts from a folder in a path with spaces and GRASS_ADDON_PATH no longer recognizes spaces.
Take a look below...
GRASS 7.0.svn (Spearfish60_test):~ > $GRASS_ADDON_PATH
bash: /Users/cmbarton/Desktop:/Users/cmbarton/Library/Application: No such file or directory
This has no trouble with the GRASS_ADDON_PATH I set in .profile (no spaces), but truncates the GRASS_ADDON_PATH set up in the Mac startup script (/Users/cmbarton/Library/Application Support/GRASS/modules/bin with spaces)
I'm changing the name of this and filing a bug report.
Michael
On Feb 14, 2010, at 9:28 PM, William Kyngesburye wrote:
This mysterious problem showed up a while back (6.3?) then went away (6.4?). Mysterious then.
For this time around, how about:
Changeset 40985 – GRASS GIS
On Feb 14, 2010, at 9:56 PM, Michael Barton wrote:
William
Do you have any clue why GRASS 7 would stop launching the GUI when opened? This change happened sometime between 11 and 14 February, and more likely in the last couple days.
Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
The above is trying the run the path as an executable. If you want to see the path in the Terminal, echo it in quotes, otherwise you will always see it 'truncated'.
echo "$GRASS_ADDON_PATH"
Michael
http://trac.osgeo.org/grass/changeset/40985
William
Michael
- Marvin
grass-dev mailing list
grass-dev@lists.osgeo.org
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
