[GRASS-dev] No Required GUI section for g.list and g.remove
Anna and I discussed the GUI sections of g.list and g.remove. The changes are now in trunk (r62248). However, few issues still remain.
It seems to us that although names and ignore in g.remove are similar from the point of view of implementation, they have completely different use case. While names is here to provide a simple interface, ignore extends the interface which is using patterns. So, non-advanced user using GUI will surely want names but not ignore and GUI should reflect this. Thus ignore should probably go to Pattern (although it is not 100% consistent) and names to some basic category.
Also, Required section (of both g.remove and g.list) contains just one item - type. In case of g.remove, it could make sense to have the names together with type in some Basic section which would be the primary section users can focus on (besides approval by -f in Optional). This of course expects that no elements will be added to the type list (#2440, #2437).
So, the big question is if we want to allow Required section to be overridden by another section if it is provided. Currently if option is required, GUI puts it into Required section no matter if another GUI section was specified.
Thanks for your opinions,
Vaclav
r62248 http://trac.osgeo.org/grass/changeset/62248
#2440 http://trac.osgeo.org/grass/ticket/2440
#2437 http://trac.osgeo.org/grass/ticket/2437
Putting the ‘ignore’ option in separate tab with patterns is fine I think. Also, for g.remove to have the ‘type’ and ‘name’ together in one tab is also a good idea imho.
I am not sure I understand the last question; you mean to add the possibility to make an option required but still have the option to put it in another section? I think that would be a good idea, not only in this case, but more in general, it would make it easier to create an consistent interface for modules that require more than a few inputs. It might be a good idea to flag options as required, e.g., by adding ‘(required)’ after the option name?
On a side note, why the -f flag of g.remove is in the ‘optional’ tab? I understand it is optional, but as you noted, it is a primary option… it is essential to do what the function is suppose to do, remove layers. As a new user I would not expect such an essential option in the optional tab I think.
Paulo
On 14-10-14 04:17, Vaclav Petras wrote:
Vaclav
grass-dev mailing list
[grass-dev@lists.osgeo.org](mailto:grass-dev@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-dev](http://lists.osgeo.org/mailman/listinfo/grass-dev)
On 14/10/14 09:14, Paulo van Breugel wrote:
Putting the 'ignore' option in separate tab with patterns is fine I
think. Also, for g.remove to have the 'type' and 'name' together in one
'(required)' after the option name?
I'm not sure I agree with this as this would leave the door open for required flags to be disseminated across several sections. I like the fact that the use immediately sees what is required to run the module.
Moritz
On Tue, Oct 14, 2014 at 10:06 AM, Moritz Lennert <
I guess it is a matter of preference. There are some grey area or cases
where this separate 'required' tab does not really work i.m.h.o.
The '-f' flag in g.remove is one example. You can run the module without
(so it shouldn't go in the 'required' tab), but you can't do what the
module is basically meant to do without it, which is removing layers (so in
that sense it should be a required choice).
Perhaps a better example is r.random. One of the required options is the
output layer. That can be a raster layer, a vector layer or both. Because
of this construct, the required output name cannot be marked as required.
Solution is to use a separate tab 'optional' where the user can provide the
output name of the vector, raster or both layers. So the user has to fill
in required information in a 'required tab' and an 'optional' tab. I don't
think it is really problematic as failing to give the output name results
in a clear error message, but it isn't exactly consistent.
But at the end, for me any solution would be fine, as long as it is clearly
described and error messages are clear (and it would of course be nice if
where possible the number of clicks or scrolling are minimized).
Moritz
        in one
        to put
        only in
        inputs.
    module.
in that sense it should be a required choice).
Because of this construct, the required output name cannot be marked as
required. Solution is to use a separate tab 'optional' where the user
can provide the output name of the vector, raster or both layers. So the
user has to fill in required information in a 'required tab' and an
'optional' tab. I don't think it is really problematic as failing to
give the output name results in a clear error message, but it isn't
exactly consistent.
The new options to declare parameters as mutually exclusive or as "at least one is requried of the group" might be a solution to that, but no idea how to implement this in the GUI.
If we want to go a simpler road, I think I would be more in favour of allowing some optional parameters in the required section (but marking them clearly as optional), than to move any required parameters to other sections than 'Required'.
Moritz
On Tue, Oct 14, 2014 at 5:28 AM, Moritz Lennert <
fine I
        in one
        to put
        only in
an
        inputs.
adding
    module.
exactly consistent.
Put this to GUI is certainly needed but challenging and I it will not be
included in 7.0. Perhaps we should put this to the manual in some way. But
modules are not using it anyway.
Anyway, these "at least one required" are causing Required section to be
less and less used, so that's another reason why it makes sense to leave it
out sometimes.
I think that the opposite is true. Having 'optional' in Required section
would defeat the purpose of Required section. And if we consider that
options which are in group "one of them required" are spread in other
sections than Required, then putting standard 'required' options to other
sections is nothing new.
And yes, we need to go a simpler road for now.
Vaclav
Moritz
On Tue, Oct 14, 2014 at 8:58 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
I think it makes thanks to ‘override’ the required property with the guisection. If we do it for a module, we should make sure there is no Required tab at all. I think having required parameters in custom tabs and eliminate Required tab is totally fine. Having Required tab and at the same time have required parameters in other sections would not work well.
Also we could mark the required options in the gui somehow, for example add a red star? In the code I see attempts to render the labels as bold, it is not used eventually, but I don’t think bold is the best way anyway.
Anna
On Tue, Oct 14, 2014 at 5:28 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)> wrote:
in one
to put
only in
inputs.
I’m not sure I agree with this as this would leave the door open for
module.
where this separate ‘required’ tab does not really work i.m.h.o.
The ‘-f’ flag in g.remove is one example. You can run the module without
(so it shouldn’t go in the ‘required’ tab), but you can’t do what the
required. Solution is to use a separate tab ‘optional’ where the user
user has to fill in required information in a ‘required tab’ and an
‘optional’ tab. I don’t think it is really problematic as failing to
give the output name results in a clear error message, but it isn’t
exactly consistent.
The new options to declare parameters as mutually exclusive or as “at least one is requried of the group” might be a solution to that, but no idea how to implement this in the GUI.
Put this to GUI is certainly needed but challenging and I it will not be included in 7.0. Perhaps we should put this to the manual in some way. But modules are not using it anyway.
Anyway, these “at least one required” are causing Required section to be less and less used, so that’s another reason why it makes sense to leave it out sometimes.
If we want to go a simpler road, I think I would be more in favour of allowing some optional parameters in the required section (but marking them clearly as optional), than to move any required parameters to other sections than ‘Required’.
I think that the opposite is true. Having ‘optional’ in Required section would defeat the purpose of Required section. And if we consider that options which are in group “one of them required” are spread in other sections than Required, then putting standard ‘required’ options to other sections is nothing new.
Vaclav
Moritz
(attachments)
On Tue, Oct 14, 2014 at 11:56 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
I attached screenshots with using the red star for required options (and in this case I was also testing when the guisection is preferred to required). In my opinion, it gives you good idea what is required or not. There are some problems coming from the wxPython limitations, for example the one which you see on the second screenshot: when the label is part of the border, I can’t set the asterisk red, the color can be changed only for the entire label. But for majority options, it works.
Regarding the required vs. guisection, I really think we should try to organize the options logically, not based on required/optional. Some distinction of the required options is then needed and the red asterisk seems to be a good solution. But we can discuss some other options too, of course.
Anna
in one
to put
only in
inputs.
module.
exactly consistent.
Anna
Vaclav
Moritz
On Sat, Oct 25, 2014 at 2:58 AM, Anna Petrášová <kratochanna@gmail.com>
wrote:
wrote:
fine I
together
        in one
the
option
        to put
        only in
create an
        inputs.
adding
for
    module.
without
(so
the
the
exactly consistent.
out sometimes.
I think it makes thanks to 'override' the required property with the
is not used eventually, but I don't think bold is the best way anyway.
the border, I can't set the asterisk red, the color can be changed only for
This is excellent. Red stars are nice but even in grey it works fine. It is
a fairly common practise to mark required options / entries this way so
this will probably work for most users
course.
I totally agree, I think this is the way to go.
Anna
Anna
that options which are in group "one of them required" are spread in other
Vaclav
Moritz
On Sat, Oct 25, 2014 at 4:55 AM, Paulo van Breugel <p.vanbreugel@gmail.com>
wrote:
wrote:
fine I
together
        in one
the
option
        to put
        only in
create an
        inputs.
adding
for
    module.
cases
without
(so
the
as
the
exactly consistent.
be less and less used, so that's another reason why it makes sense to leave
it out sometimes.
is a fairly common practise to mark required options / entries this way so
course.
I committed it in r62403. I will have to adjust guisections in several
modules to reflect the changes.
Anna
Anna
Vaclav
Moritz
On 25/10/14 02:58, Anna Petrášová wrote:
<mailto:kratochanna@gmail.com>> wrote:
                <mailto:mlennert@club.__worldonline.be
                and 'name' together
                         in one
                you mean to add the
                         to put
                good idea, not
                         only in
                more than a few
                         inputs.
                the door open for
                sections. I like
                required to run the
                     module.
                grey area or cases
                i.m.h.o.
                the module without
                can't do what the
                removing layers (so
                or both.
                cannot be marked as
                where the user
                both layers. So the
                tab' and an
                as failing to
                but it isn't
                exactly consistent.
        section to be less and less used, so that's another reason why
    labels as bold, it is not used eventually, but I don't think bold is
is part of the border, I can't set the asterisk red, the color can be
of course.
If you really want to go down that path (it would get a 0 from me), then please remove the required tab completely. It will be very confusing to have a required section, but not with all required parameters in it.
I personally like the way the required tab focuses attention on the most important parameters, even though I do understand that there are ambiguities that this system creates. I'm not sure, though, that getting rid of the required tab is the solution. But if you go in that direction it should be all the way.
Moritz
Moritz
On Tue, Oct 28, 2014 at 10:31 AM, Moritz Lennert <
                and 'name' together
                         in one
                you mean to add the
                         to put
                good idea, not
                         only in
                more than a few
                         inputs.
                the door open for
                sections. I like
                required to run the
                     module.
                grey area or cases
                i.m.h.o.
                the module without
                can't do what the
                removing layers (so
                or both.
                cannot be marked as
                where the user
                both layers. So the
                tab' and an
                as failing to
                but it isn't
                exactly consistent.
GUI.
of course.
Right. The modules which have required options in some other sections than
Required, should not have the Required section.
We are not getting rid of it completely. If it is appropriate for the
module, it can use it. It is still the default. The point is that for some
modules there is no Required tab because of different ways to specify
inputs (e.g. map names in file vs map names in parameter) and for some of
the modules there is more logical way of organizing parameters than
Required vs optional (Optional section or general sections). Enabling
required parameters outside Required section is addressing the later case.
Moritz
Moritz
On Tue, Oct 28, 2014 at 3:31 PM, Moritz Lennert <
                and 'name' together
                         in one
                you mean to add the
                         to put
                good idea, not
                         only in
                more than a few
                         inputs.
                the door open for
                sections. I like
                required to run the
                     module.
                grey area or cases
                i.m.h.o.
                the module without
                can't do what the
                removing layers (so
                or both.
                cannot be marked as
                where the user
                both layers. So the
                tab' and an
                as failing to
                but it isn't
                exactly consistent.
GUI.
of course.
Agree
I understand these boil down to different preferences.. but just to argue
further in favour of the proposed changes.. from my own user experience,
and now from trying to train a colleague in using GRASS GIS.. what most
unambiguously focusses attention to the most important parameters is the
initial tab that opens when opening the window. This is now most often the
'required' tab, but it needn't be.
Moritz
Moritz
                and 'name' together
                         in one
                you mean to add the
                         to put
                good idea, not
                         only in
                more than a few
                         inputs.
                the door open for
                sections. I like
                required to run the
                     module.
                grey area or cases
                i.m.h.o.
                the module without
                can't do what the
                removing layers (so
                or both.
                cannot be marked as
                where the user
                both layers. So the
                tab' and an
                as failing to
                but it isn't
                exactly consistent.
GUI.
of course.
Well, there are already modules which already don't have required tab
(r.colors, many t.* modules). Also a lot of modules have required tab but
it is more confusing than helpful. Do you require to remove Required tab
from all the modules? Even from modules where it still makes sense? Or you
are talking about the case when the option is required but the guisection
is specified, so it would get into a different tab? For the first option,
we would have to go through all modules (several hundreds) and come up with
some substitute, that's not feasible.
Anna
Moritz
Moritz
        <kratochanna@gmail.com <mailto:kratochanna@gmail.com>
        <mailto:kratochanna@gmail.com>__>
        wrote:
        <wenzeslaus@gmail.com <mailto:wenzeslaus@gmail.com>
        <mailto:mlennert@club.>__worldo__nline.be <http://worldonline.be>
        separate tab
        'type'
                         and 'name' together
                                  in one
        question;
                         you mean to add the
                                  to put
        would be a
                         good idea, not
                                  only in
        would make
        require
                         more than a few
                                  inputs.
        would leave
                         the door open for
        several
                         sections. I like
                         required to run the
                              module.
        some
                         grey area or cases
        really work
                         i.m.h.o.
        can run
                         the module without
                         can't do what the
        which is
                         removing layers (so
        vector layer
                         or both.
                         cannot be marked as
        'optional'
                         where the user
        raster or
                         both layers. So the
        'required
                         tab' and an
        problematic
                         as failing to
        message,
                         but it isn't
                         exactly consistent.
        exclusive
        be a
        in the GUI.
        I it
        to the
        reason why
        with the
        there is
        in custom
        Required tab
        render the
        think bold is
        options (and
        limitations, for
        label
        can be
        works.
        try to
        asterisk
        options too,
        of course.
    parameters in it.
but it is more confusing than helpful. Do you require to remove Required
tab from all the modules? Even from modules where it still makes sense?
Or you are talking about the case when the option is required but the
guisection is specified, so it would get into a different tab? For the
first option, we would have to go through all modules (several hundreds)
and come up with some substitute, that's not feasible.
No, I agree with what Vaclav said: for those modules where required options are all in the required section, this should stay. However, if in a module you put required parameters in other sections, then there should be no more required section for that module.
Moritz
On Tue, Oct 28, 2014 at 1:38 PM, Moritz Lennert <
        wrote:
        separate tab
        'type'
                         and 'name' together
                                  in one
        question;
                         you mean to add the
but
                                  to put
        would be a
                         good idea, not
                                  only in
        would make
        require
                         more than a few
                                  inputs.
as
        would leave
                         the door open for
        several
                         sections. I like
is
                         required to run the
                              module.
        some
                         grey area or cases
        really work
                         i.m.h.o.
        can run
                         the module without
you
                         can't do what the
        which is
                         removing layers (so
        vector layer
                         or both.
name
                         cannot be marked as
        'optional'
                         where the user
        raster or
                         both layers. So the
        'required
                         tab' and an
        problematic
                         as failing to
        message,
                         but it isn't
                         exactly consistent.
        exclusive
        be a
        in the GUI.
        I it
        to the
Required
        reason why
        with the
        there is
        in custom
        Required tab
sections
for
        render the
        think bold is
        options (and
to
or
        limitations, for
        label
        can be
        works.
        try to
Some
        asterisk
        options too,
        of course.
    parameters in it.
Good, I was not sure. I found a couple of modules which have this problem,
I already tried to reorganize at least the most used ones, will commit it
soon. Some more feedback would be welcome on g.remove layout. Also, I
realized r.horizon would need some better organization of options, but I am
not sure how.
Moritz
On Tue, Oct 28, 2014 at 3:54 PM, Anna Petrášová <kratochanna@gmail.com>
        wrote:
        separate tab
        'type'
                         and 'name' together
                                  in one
        question;
                         you mean to add the
but
                                  to put
        would be a
                         good idea, not
                                  only in
        would make
        require
                         more than a few
                                  inputs.
options as
        would leave
                         the door open for
        several
                         sections. I like
what is
                         required to run the
                              module.
        some
                         grey area or cases
        really work
                         i.m.h.o.
        can run
                         the module without
you
                         can't do what the
        which is
                         removing layers (so
        vector layer
                         or both.
name
                         cannot be marked as
        'optional'
                         where the user
        raster or
                         both layers. So the
        'required
                         tab' and an
        problematic
                         as failing to
        message,
                         but it isn't
                         exactly consistent.
        exclusive
        be a
        in the GUI.
        I it
        to the
Required
        reason why
        with the
        there is
        in custom
        Required tab
sections
for
        render the
        think bold is
        options (and
to
required or
        limitations, for
        label
        can be
        works.
        try to
Some
        asterisk
        options too,
        of course.
    parameters in it.
not sure how.
Some changes done in r62466.
Moritz
Whoever creates/maintains a module can of course always decide whether to use a tab with the name ‘required’. A question is what would you want to happens if you write an addon and mark on option as ‘required’. Now it goes to the ‘required’ tab. The suggested alternative was that it gets marked by a red star, but it is up to the creator of the script to decide to what tab it goes? So these options can still go into a ‘required’ tab (don’t know how implementing this impacts existing modules, I guess you don’t want to do this manually for all existing modules)
<kratochanna@gmail.com mailto:kratochanna@gmail.com
<mailto:kratochanna@gmail.com mailto:kratochanna@gmail.com>__>
wrote:
<wenzeslaus@gmail.com mailto:wenzeslaus@gmail.com
mailto:mlennert@club.__worldo__nline.be http://worldonline.be
separate tab
‘type’
and ‘name’ together
in one
question;
you mean to add the
to put
would be a
good idea, not
only in
would make
require
more than a few
inputs.
would leave
the door open for
several
sections. I like
required to run the
module.
some
grey area or cases
really work
i.m.h.o.
can run
the module without
can’t do what the
which is
removing layers (so
vector layer
or both.
cannot be marked as
‘optional’
where the user
raster or
both layers. So the
‘required
tab’ and an
problematic
as failing to
message,
but it isn’t
exactly consistent.
exclusive
be a
in the GUI.
I it
to the
reason why
with the
there is
in custom
Required tab
render the
think bold is
options (and
limitations, for
label
can be
works.
try to
asterisk
options too,
of course.
parameters in it.
are ambiguities that this system creates. I’m not sure, though, that
Well, there are already modules which already don’t have required tab
and come up with some substitute, that’s not feasible.
Moritz
