[GRASS-dev] Notice about --with-ffmpeg and preC99 compilers
could somebody add a notice to INSTALL file that using --with-ffmpeg breaks
build with preC99 compilers as ffmpeg include files use one line comments //,
that where introduced with C99.
Tested on GNU/Linux x86
gcc version 4.1.2 20060920 (prerelease)
ffmpeg 3:0.cvs20060823
You can test it by yourself as described in doc/debuging.txt:
compile GRASS with
CFLAGS='-g -ansi -Wall -D_BSD_SOURCE=1 -D_SVID_SOURCE=1 -D_POSIX_SOURCE=1 -D_POSIX_C_SOURCE=199506L'
WBR,
Maris.
Error message:
gcc -I/home/maris/soft/grass-6.2.0RC1/dist.i686-pc-linux-gnu/include -g -ansi -Wall -D_BSD_SOURCE=1 -D_SVID_SOURCE=1 -D_POSIX_SOURCE=1 -D_POSIX_C_SOURCE=199506L -fPIC -DPACKAGE=\""grasslibs"\" -I/usr/include -DPACKAGE=\""grasslibs"\" -I/usr/include/ffmpeg/ -I/home/maris/soft/grass-6.2.0RC1/dist.i686-pc-linux-gnu/include
                -o OBJ.i686-pc-linux-gnu/gsd_img_ppm.o -c gsd_img_ppm.c
In file included from /usr/include/ffmpeg/avutil.h:24,
                 from /usr/include/ffmpeg/avcodec.h:14,
                 from gsd_img_ppm.c:19:
/usr/include/ffmpeg/common.h:171: error: expected identifier or ‘(’ before ‘/’
token
/usr/include/ffmpeg/common.h:185: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
or ‘__attribute__’ before ‘int’
