[GRASS-dev] numpy problem by winGRASS7 startup
hi,
when starting winGRASS on a new windows machine, I get following error:
Cleaning up temporary files...
Starting GRASS GIS...
WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
         nicht möglich.
          __________ ___ __________ _______________
         / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
        / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
       \____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.3.svn (r68855)
GRASS GIS homepage: http://grass.osgeo.org
This version running through: Command Shell
(C:\Windows\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. Alle Rechte vorbehalten.
C:\>Numeric,numarray or NumPy not found.
            This module requires the Numeric/numarray or NumPy module,
            which could not be imported. It probably is not installed
            (it's not part of the standard Python distribution). See the
            Numeric Python site (http://numpy.scipy.org) for information on
            downloading source or binaries.
System Info
GRASS Version: 7.3.svn
GRASS SVN revision: r68855
Build date: 2016-07-06
Build platform: x86_64-w64-mingw32
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
any idea? numpy is installed in the OSGeo4W-stack ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/numpy-problem-by-winGRASS7-startup-tp5275239.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Thu, Jul 7, 2016 at 7:07 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
https://trac.osgeo.org/grass/ticket/3057
Perhaps that ticket?
Hi Helmut,
That is exactly the same issue I reported some time back (https://lists.osgeo.org/pipermail/grass-user/2016-June/074347.html) and opened the ticket Markus just pointed out… I cannot test again now, but I had the same problem until last week, and that also implied that g.gui.tplot and g.gui.timeline didn’t work, for example…
Hope someone could address that issue…
Vero
2016-07-07 14:39 GMT-03:00 Markus Neteler <neteler@osgeo.org>:
hi,
Cleaning up temporary files…
Starting GRASS GIS…
Launching GUI in the background, please wait…
C:>Numeric,numarray or NumPy not found.
(it’s not part of the standard Python distribution). See the
grass-dev mailing list
grass-dev@lists.osgeo.org
2016-07-07 19:07 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
please try tomorrow build, they were some updates, I hope it be
automagically solved :wink: Ma
System Info
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
best regards
Helmut
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
2016-07-07 19:07 GMT+02:00 Helmut Kudrnovsky <[hidden email]>:
tested with
System Info
GRASS SVN revision: r68875
Build date: 2016-07-07
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
still the same issue.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/numpy-problem-by-winGRASS7-startup-tp5275239p5275340.html
