Here is colored vector patch for nviz. It uses grassrgb attribute to get line
colors. Displaying of line vectors should work, area vectors aren't
implemented.
Radek Bartoň
(attachments)
diff.txt (4.42 KB)
implemented.
Radek Bartoň
diff.txt (4.42 KB)
get line colors. Displaying of line vectors should work, area vectors
aren't implemented.
Hi Radek,
thanks for the patch, can you please re-send it as a "unidiff"?
cvs diff -u grass6/lib/ogsf/
"diff -u" provides context to the changes and is safer to use.
thanks,
Hamish
> aren't implemented.Hi Radek,
Better still, add "diff -u" to your ~/.cvsrc file.
Nobody uses diff's default output format; most people use either the
context (-c) or unified (-u) formats.
> > aren't implemented.
> Hi Radek,
> cvs diff -u grass6/lib/ogsf/Better still, add "diff -u" to your ~/.cvsrc file.
OK, here is new diff.
الظفر بالضعيف هزيمة
diff2.txt (6.42 KB)
