After compiling and installing latest cvs following William's readme, I got this error when trying nviz (itt works fine when using his binaries):
Date/Time: 2007-04-19 13:10:33.116 +0200
OS Version: 10.4.9 (Build 8P2137)
Report Version: 4
Command: nviz
Path: /Applications/GRASS-6.3.app/Contents/Resources/etc/nviz2.2/nviz
Parent: wish8.4 [15392]
Version: ??? (???)
PID: 15397
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0x6e614320
Thread 0 Crashed:
0 libX11.6.dylib 0x005dacd2 XQueryExtension + 51
1 libGL.1.dylib 0x005655f3 glXQueryExtension + 62
2 nviz 0x00016aa8 Togl_CreateWindow + 79
3 com.tcltk.tklibrary 0x9ad55131 Tk_MakeWindowExist + 120
4 nviz 0x00016992 Togl_Cmd + 1194
5 com.tcltk.tcllibrary 0x9ac5416f TclInvokeStringCommand + 121
6 com.tcltk.tcllibrary 0x9ac568e1 TclEvalObjvInternal + 733
7 com.tcltk.tcllibrary 0x9ac7965a TclExecuteByteCode + 3101
8 com.tcltk.tcllibrary 0x9ac7e442 TclCompEvalObj + 279
9 com.tcltk.tcllibrary 0x9aca5261 TclObjInterpProc + 524
10 com.tcltk.tcllibrary 0x9ac568e1 TclEvalObjvInternal + 733
11 com.tcltk.tcllibrary 0x9ac56be8 Tcl_EvalEx + 488
12 com.tcltk.tcllibrary 0x9ac94930 Tcl_FSEvalFile + 400
13 com.tcltk.tcllibrary 0x9ac94a14 Tcl_EvalFile + 47
14 com.tcltk.tklibrary 0x9ad2b291 Tk_MainEx + 835
15 nviz 0x0001517a main + 126
16 nviz 0x000023aa _start + 216
17 nviz 0x000022d1 start + 41
Thread 1:
0 libSystem.B.dylib 0x9001a0ec select + 12
1 libSystem.B.dylib 0x90024147 _pthread_body + 84
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x6e614328 ebx: 0x005655c3 ecx: 0x00016a59 edx: 0x6e614320
edi: 0xbfffcce4 esi: 0x01cd5008 ebp: 0xbfffcbd8 esp: 0xbfffcba0
ss: 0x0000001f efl: 0x00010283 eip: 0x005dacd2 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x26fff nviz /Applications/GRASS-6.3.app/Contents/Resources/etc/nviz2.2/nviz
0x34000 - 0x35fff libgrass_bitmap.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_bitmap.dylib
0x39000 - 0x39fff libgrass_linkm.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_linkm.dylib
0x3d000 - 0x3efff libgrass_form.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_form.dylib
0x70000 - 0xc9fff libgrass_ogsf.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_ogsf.dylib
0xe0000 - 0xe5fff libgrass_datetime.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_datetime.dylib
0xea000 - 0xedfff libgrass_sites.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_sites.dylib
0xf2000 - 0xf6fff libgrass_dbmiclient.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_dbmiclient.dylib
0xfd000 - 0xfdfff com.kyngchaos.UnixImageIO 1.0.12 (UnixImageIO 1.0.13) /Library/Frameworks/UnixImageIO.framework/Versions/A/UnixImageIO
0x205000 - 0x21efff libgrass_g3d.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_g3d.dylib
0x228000 - 0x26bfff libgrass_gis.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_gis.dylib
0x281000 - 0x289fff libgrass_dbmibase.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_dbmibase.dylib
0x292000 - 0x2bffff libgrass_vect.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_vect.dylib
0x2cb000 - 0x2dffff libgrass_dgl.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_dgl.dylib
0x2e6000 - 0x2f6fff libgrass_dig2.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_dig2.dylib
0x2fd000 - 0x301fff libgrass_rtree.dylib /Applications/GRASS-6.3.app/Contents/Resources/lib/libgrass_rtree.dylib
0x305000 - 0x309fff libSM.6.dylib /usr/X11R6/lib/libSM.6.dylib
0x30e000 - 0x31dfff libICE.6.dylib /usr/X11R6/lib/libICE.6.dylib
0x325000 - 0x333fff libXmu.6.dylib /usr/X11R6/lib/libXmu.6.dylib
0x33b000 - 0x343fff libXext.6.dylib /usr/X11R6/lib/libXext.6.dylib
0x34a000 - 0x34afff net.refractions.geos 3.0.0 (GEOS 3.0.0-rc4) /Library/Frameworks/GEOS.framework/Versions/3.0/GEOS
0x34d000 - 0x353fff libgeosc.dylib /Library/Frameworks/GEOS.framework/Versions/3.0/Libraries/libgeosc.dylib
0x35f000 - 0x363fff libgif.dylib /Library/Frameworks/UnixImageIO.framework/Versions/A/Libraries/libgif.dylib
0x4b0000 - 0x50bfff libGLU.1.dylib /usr/X11R6/lib/libGLU.1.dylib
0x536000 - 0x590fff libGL.1.dylib /usr/X11R6/lib/libGL.1.dylib
0x5c4000 - 0x681fff libX11.6.dylib /usr/X11R6/lib/libX11.6.dylib
0x6a9000 - 0x6d5fff org.maptools.proj 4.5.0 (PROJ 4.5.0-4) /Library/Frameworks/PROJ.framework/Versions/4.5/PROJ
0x6e1000 - 0x72bfff org.sqlite.sqlite3 3.3.14 (SQLite3 3.3.14-1) /Library/Frameworks/SQLite3.framework/Versions/3.3/SQLite3
0x738000 - 0x751fff libjpeg.dylib /Library/Frameworks/UnixImageIO.framework/Versions/A/Libraries/libjpeg.dylib
0x757000 - 0x78bfff libjasper.dylib /Library/Frameworks/UnixImageIO.framework/Versions/A/Libraries/libjasper.dylib
0x79e000 - 0x7b8fff libpng.dylib /Library/Frameworks/UnixImageIO.framework/Versions/A/Libraries/libpng.dylib
0x1008000 - 0x12f7fff org.gdal.gdal 1.4.1 (GDAL 1.4.1-1) /Library/Frameworks/GDAL.framework/Versions/1.4/GDAL
0x14b8000 - 0x16d1fff Xerces /Library/Frameworks/Xerces.framework/Versions/A/Xerces
0x1919000 - 0x19d1fff libgeos.dylib /Library/Frameworks/GEOS.framework/Versions/3.0/Libraries/libgeos.dylib
0x1b0a000 - 0x1bb0fff libXpm.dylib /Library/Frameworks/UnixImageIO.framework/Versions/A/Libraries/libXpm.dylib
0x1bcc000 - 0x1c18fff libtiff.dylib /Library/Frameworks/UnixImageIO.framework/Versions/A/Libraries/libtiff.dylib
0x1c23000 - 0x1c5cfff libXt.6.dylib /usr/X11R6/lib/libXt.6.dylib
0x8fe00000 - 0x8fe4afff dyld 46.12 /usr/lib/dyld
0x90000000 - 0x90172fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901c2000 - 0x901c4fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c6000 - 0x90203fff com.apple.CoreText 1.1.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9022a000 - 0x90300fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90320000 - 0x90775fff com.apple.CoreGraphics 1.258.61 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9080c000 - 0x908d4fff com.apple.CoreFoundation 6.4.7 (368.28) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90912000 - 0x90912fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90914000 - 0x90a07fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a57000 - 0x90ad6fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aff000 - 0x90b63fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bd2000 - 0x90bd9fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bde000 - 0x90c51fff com.apple.framework.IOKit 1.4.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c66000 - 0x90c78fff libauto.dylib /usr/lib/libauto.dylib
0x90c7e000 - 0x90f24fff com.apple.CoreServices.CarbonCore 682.18 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f67000 - 0x90fcffff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91008000 - 0x91046fff com.apple.CFNetwork 129.20 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91059000 - 0x91069fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91074000 - 0x910f3fff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9112d000 - 0x9114bfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91157000 - 0x91165fff libz.1.dylib /usr/lib/libz.1.dylib
0x91168000 - 0x91307fff com.apple.security 4.5.2 (29774) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91405000 - 0x9140dfff com.apple.DiskArbitration 2.1.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91414000 - 0x9143afff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9144c000 - 0x91453fff libbsm.dylib /usr/lib/libbsm.dylib
0x91457000 - 0x914cdfff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9151e000 - 0x9151efff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91520000 - 0x9154cfff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9155f000 - 0x91633fff com.apple.ColorSync 4.4.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9166e000 - 0x916e1fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9170f000 - 0x917b8fff com.apple.QD 3.10.24 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917de000 - 0x91829fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91848000 - 0x9185efff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9186a000 - 0x91885fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91890000 - 0x918cdfff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918e1000 - 0x918edfff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918f4000 - 0x91933fff com.apple.ImageIO.framework 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91946000 - 0x919f8fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a3e000 - 0x91a54fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a59000 - 0x91a77fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a7c000 - 0x91adbfff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91aed000 - 0x91af1fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91af3000 - 0x91b77fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b7b000 - 0x91bb8fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91bbe000 - 0x91bd8fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91bdd000 - 0x91bdffff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91be1000 - 0x91cbffff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91cdc000 - 0x91cdcfff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91cde000 - 0x91d6cfff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91d73000 - 0x91d73fff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91d75000 - 0x91dcefff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91dd7000 - 0x91dfbfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91e03000 - 0x9220cfff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92246000 - 0x925fafff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92627000 - 0x92714fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92716000 - 0x92793fff com.apple.DesktopServices 1.3.6 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x927d4000 - 0x92a04fff com.apple.Foundation 6.4.8 (567.29) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92b1e000 - 0x92b35fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92b40000 - 0x92b98fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92bac000 - 0x92bacfff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92bae000 - 0x92bbefff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92bcd000 - 0x92bd5fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92bdb000 - 0x92be1fff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92be7000 - 0x92c78fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c8c000 - 0x92c90fff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92c93000 - 0x92cb1fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92cc3000 - 0x92cc9fff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92ccf000 - 0x92d32fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92d59000 - 0x92d9afff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92dc1000 - 0x92dcffff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92dd6000 - 0x92ddbfff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92de0000 - 0x930d5fff com.apple.HIToolbox 1.4.9 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x931db000 - 0x931e6fff com.apple.opengl 1.4.16 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94293000 - 0x942a2fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x942a9000 - 0x942b4fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94300000 - 0x9431afff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9496d000 - 0x94992fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
0x97849000 - 0x97887fff libiodbc.2.dylib /usr/lib/libiodbc.2.dylib
0x97894000 - 0x9789dfff libiodbcinst.2.dylib /usr/lib/libiodbcinst.2.dylib
0x9a785000 - 0x9a790fff libXplugin.1.dylib /usr/lib/libXplugin.1.dylib
0x9ac47000 - 0x9acc5fff com.tcltk.tcllibrary 8.4.7 a /System/Library/Frameworks/Tcl.framework/Versions/8.4/Tcl
0x9acdf000 - 0x9ad8efff com.tcltk.tklibrary 8.4.7 a /System/Library/Frameworks/Tk.framework/Versions/8.4/Tk
Model: iMac5,1, BootROM IM51.0090.B03, 2 processors, Intel Core 2 Duo, 2 GHz, 2 GB
Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 128 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x87), Broadcom BCM43xx 1.0 (4.80.79.1)
Bluetooth: Version 1.7.14f14, 2 service, 1 devices, 1 incoming serial ports
Network Service: Built-in Ethernet, Ethernet, en0
Network Service: Parallels Host-Guest, Ethernet, en2
Network Service: Parallels NAT, Ethernet, en3
Serial ATA Device: ST3160812AS Q, 149.05 GB
Parallel ATA Device: MATSHITADVD-R UJ-85J
USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
USB Device: USB HUB, Up to 12 Mb/sec, 500 mA
USB Device: Bluetooth HCI, Up to 12 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: USB-PS/2 Optical Mouse, Logitech, Up to 1.5 Mb/sec, 100 mA
USB Device: HASP 2.17, AKS, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
FireWire Device: LaCie Hard Drive FireWire+, LaCie Group SA, Up to 400 Mb/sec
FireWire Device: LaCie d2 Extreme LUN 0, LaCie Group SA, Up to 400 Mb/sec
grass-dev@grass.itc.it
