I am building GRASS6.4 from source on a computation cluster. GRASS itself is up and running, but NVIZ causes trouble:
When invoking NVIZ from the GRASS command line (nviz -q), the NVIZ command window pops up and throws this error message:
Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 3 (X_GetWindowAttributes)
Resource id in failed request: 0xffffffff
Serial number of failed request: 237
Current serial number in output stream: 238
Any help/comment/advice would be much appreciated.
Are you using "ssh -X"? Tk needs "ssh -Y" (or ForwardX11Trusted).
Datum: Fri, 18 Mar 2011 17:41:24 +0200
Von: Maris Nartiss <maris.gis@gmail.com>
An: peter.loewe@gmx.de
CC: grass-dev@lists.osgeo.org
Betreff: Re: [GRASS-dev] NVIZ Error: Error of failed request: BadWindow
glxgears working fine?
OpenGL system vs NVIZ/OGSF compiled in OpenGL system?
export LIBGL_ALWAYS_INDIRECT=1 && nviz ?
Maris.
2011/3/18, peter.loewe@gmx.de <peter.loewe@gmx.de>:
> Hi all,
itself is
command
> Hi all,
today I get the same error, Debian/stable (squeeze) on amd64, tunneled
X over ssh, both 'ssh -X' and 'ssh -Y' fail. I thought I'd add another
data point for the ML archives.
(this is nothing to do with the just reported --ui bug btw)
Maris:
nope. glxinfo fails too.
the same setup was working fine for me until now, not sure what changed.
