[GRASS-dev] NVIZ error in 6.4
For some reason when attemtpting to run NVIZ from wxPython (GRASS 6.4) the
command line tells me that the process has been killed after about 40
seconds, with no results showing. Any ideas why this might be happening?
Does my computer just suck?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/NVIZ-error-in-6-4-tp6730852p6730852.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
after about 40
be happening?
the specific error message means you ran of memory.
probably this is because the computational region is set at a
ridiculously huge size.
try 'g.region -p', the number of rows and columns shouldn't
usually exceed 45000x45000 unless you have a fast 64bit machine
with lots of RAM. Typical values are in the 2000x2000 range.
before running nviz, try setting the region to match the map
with 'g.region rast=your_map'
Hamish
