H_B
1
still on the 3D faces theme,
in the NVIZ panel menu we have:
Surface
Vector Lines
Vector Points
Volumes
The "Vector Lines" panel actually controls 3D faces as well.
I was going to change it to be "Vector Lines and Surfaces", but
then the menu reads:
Surface
Vector Points
Volumes
... too many "Surfaces". I'm at a loss as to what name it.
e.g.
Raster Surfaces
Raster Volumes
Vector Points
anyone have a bright idea?
AFAIK vector areas are still unsupported in NVIZ?
Will "v.type type=boundary,face" work around that?
Hamish
On Wed, Jun 14, 2006 at 09:59:30PM +1200, Hamish wrote:
Surface
Vector Lines
Vector Points
Volumes
Surface
what about
Vector Lines and 3D Polygons
Vector Points
Volumes
Surfaces is sort of reserved for raster maps in NVIZ.
e.g.
Raster Surfaces
Raster Volumes
Vector Points
mine above?
You mean that "soils" in Spearfish is rendered as boundaris
only?
I don't think so because faces are usually 3D (so v.drape?).
But I am not sure.
