[GRASS-dev] NVIZ problem on Mac
I don't know what the source of this is, but in the current 6.4 build of GRASS (last week's SVN) NVIZ doesn't seem to work under Mac OS X. It crashes when you try to start it in any mode. As usual, there is not much info about an NVIZ crash.
This is with the TclTk 8.5 aqua version. We may have to revert to x11 for Mac.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
No crashes for me. Both from CLI and GUI.
A few odd bits:
- it starts with the controls panel collapsed, though the expand/collapse widget says it's expanded. And when I click it once it stays collapsed, though the widget changes, click again and it finally expands.
- There is also an error every time I do this:
unknown option "-label"
     while executing
"$Nv_(AREA).menu.config.m entryconfigure 1 -label "Show Panels" -command "show_menus""
     (procedure "hide_menus" line 9)
     invoked from within
"hide_menus"
     invoked from within
".middle.panelarea.f1.b1 invoke"
     ("uplevel" body line 1)
     invoked from within
"uplevel #0 [list $w invoke]"
     (procedure "tk::ButtonUp" line 23)
     invoked from within
"tk::ButtonUp .middle.panelarea.f1.b1"
     (command bound to event)
- The tooltips defocus the NVIZ window, which is slightly annoying in most cases, but for popup menus (ie Decorations...) unpops the menu. Even if I'm fast enough to select a menu item, the tooltip popup still happens and the selection is ignored.
The tooltips don't affect the sliders (another GUI widget where you hold the mouse button on it for a period of time), but I wonder if that's because Tk Aqua doesn't use OSX sliders. Popup menus do use OSX menus.
Michael
USA
grass-dev mailing list
grass-dev@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
A few odd bits:
   while executing
   invoked from within
"hide_menus"
   invoked from within
   invoked from within
   invoked from within
Michael
I think this must be a problem with OS X. Both a version compiled last week and a version compiled in September, in which NVIZ *did* work now fail. I'll copy the Mac error report below. I am running 10.5.6 now. I have tried this against a self-compiled TclTk aqua and the ActiveStates version.
================= error ===============
Process: nviz [3295]
Path: /Applications/GRASS-6.4.app/Contents/MacOS/etc/nviz2.2/nviz
Identifier: nviz
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: wish8.5 [3288]
Date/Time: 2008-12-19 23:31:50.398 -0700
OS Version: Mac OS X 10.5.6 (9G55)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000002c
Crashed Thread: 0
Thread 0 Crashed:
0 nviz 0x00012a43 Togl_CreateWindow + 1371
1 com.tcltk.tklibrary 0x0b075242 Tk_MakeWindowExist + 120
2 nviz 0x00013282 Togl_Cmd + 875
3 com.tcltk.tcllibrary 0x000adaeb TclInvokeStringCommand + 117
4 com.tcltk.tcllibrary 0x000b0245 TclEvalObjvInternal + 718
5 com.tcltk.tcllibrary 0x000d2b7d TclExecuteByteCode + 3036
6 com.tcltk.tcllibrary 0x000d7cbb TclCompEvalObj + 278
7 com.tcltk.tcllibrary 0x000fe9a6 TclObjInterpProc + 521
8 com.tcltk.tcllibrary 0x000b0245 TclEvalObjvInternal + 718
9 com.tcltk.tcllibrary 0x000b054f Tcl_EvalEx + 482
10 com.tcltk.tcllibrary 0x000ee087 Tcl_FSEvalFile + 411
11 com.tcltk.tcllibrary 0x000ee16a Tcl_EvalFile + 50
12 com.tcltk.tklibrary 0x0b04bdb4 Tk_MainEx + 779
13 nviz 0x00010f71 main + 109
14 nviz 0x000026a6 start + 54
Thread 1:
0 libSystem.B.dylib 0x903c96f2 select$DARWIN_EXTSN + 10
1 libSystem.B.dylib 0x903ab095 _pthread_start + 321
2 libSystem.B.dylib 0x903aaf52 thread_start + 34
Thread 2:
0 libSystem.B.dylib 0x903813ae __semwait_signal + 10
1 libSystem.B.dylib 0x903abd0d pthread_cond_wait$UNIX2003 + 73
2 libGLProgrammability.dylib 0x94c72b32 glvmDoWork + 162
3 libSystem.B.dylib 0x903ab095 _pthread_start + 321
4 libSystem.B.dylib 0x903aaf52 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
   eax: 0x00000028 ebx: 0x000124ff ecx: 0x00758a80 edx: 0x0afbd2c8
   edi: 0x00000000 esi: 0x00758a80 ebp: 0xbfffd9c8 esp: 0xbfffd920
    ss: 0x0000001f efl: 0x00010286 eip: 0x00012a43 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
   cr2: 0x0000002c
Binary Images:
     0x1000 - 0x1efff +nviz ??? (???) <4f2c20f9670d2584f4ac4ab07a2083a0> /Applications/GRASS-6.4.app/Contents/MacOS/etc/nviz2.2/nviz
    0x31000 - 0x32ffe +libgrass_bitmap.dylib ??? (???) <da17e528135c6cc00942139974f5311b> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_bitmap.dylib
    0x36000 - 0x36ffc +libgrass_linkm.dylib ??? (???) <09989df57c72e69acf33987e2065badf> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_linkm.dylib
    0x3b000 - 0x3ffff +libgrass_datetime.dylib ??? (???) <f94f00010d1d93e32620bf59e2c06ff4> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_datetime.dylib
    0x45000 - 0x46fff +libgrass_form.dylib ??? (???) <5d5bb7b85825279a5104a5719bcc8ab3> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_form.dylib
    0x69000 - 0x6bfff +libgrass_sites.dylib ??? (???) <9fab9dfa2a3aab4adc6cc427828c2cf1> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_sites.dylib
    0x70000 - 0x74ffd +libgrass_dbmiclient.dylib ??? (???) <5625997660fa788724adb830d7c98ea7> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_dbmiclient.dylib
    0xa1000 - 0x11ffef com.tcltk.tcllibrary 8.4.7 b (8.4.7 b) <fd41897f36de9271d601298eaf7cdf4b> /System/Library/Frameworks/Tcl.framework/Versions/8.4/Tcl
   0x142000 - 0x18bfef +libgrass_ogsf.dylib ??? (???) <5577a6dde58c294842f8e990cfa92bce> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_ogsf.dylib
   0x1ab000 - 0x1bffff +libgrass_g3d.dylib ??? (???) <d303f89cc90ae249bea5446034cc0121> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_g3d.dylib
   0x1cd000 - 0x203fe7 +libgrass_gis.dylib ??? (???) <f417dc0e4044af0509bd1585040e552f> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
   0x22a000 - 0x230fff +libgrass_dbmibase.dylib ??? (???) <cf10069b267bad2237d9d36966c3cb56> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_dbmibase.dylib
   0x23e000 - 0x267ff7 +libgrass_vect.dylib ??? (???) <86d791b77fe96c321b717e78b4ca6826> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_vect.dylib
   0x27c000 - 0x28affc +libgrass_dgl.dylib ??? (???) <893db95d021fe238c7f4590b20e4b6b6> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_dgl.dylib
   0x295000 - 0x2a1fff +libgrass_dig2.dylib ??? (???) <6ddc0025f5fef102be2b8657d42a2b0b> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_dig2.dylib
   0x2ab000 - 0x2aefff +libgrass_rtree.dylib ??? (???) <84d62645ba53a4ab3a4167b334e7c542> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_rtree.dylib
   0x2b3000 - 0x374fe3 +com.kyngchaos.UnixImageIO 1.0.24 (UnixImageIO 1.0.24) <1c69c7547d232f8e4ab4376badbf290c> /Library/Frameworks/UnixImageIO.framework/Versions/B/UnixImageIO
   0x39a000 - 0x3c6ffc +org.maptools.proj 4.6.0 (PROJ 4.6.0-1) /Library/Frameworks/PROJ.framework/Versions/4.6/PROJ
   0x3d3000 - 0x48affb +net.refractions.geos 3.0.0 (GEOS 3.0.0-2) <03f109da4d5e245a5c74c04735fbd0cf> /Library/Frameworks/GEOS.framework/Versions/3.0/GEOS
   0x53c000 - 0x59bfff +org.sqlite.sqlite3 3.5.9 (SQLite3 3.5.9-2) <ee297b08a606167691642d468fa1abd2> /Library/Frameworks/SQLite3.framework/Versions/3/SQLite3
   0x5a7000 - 0x5e6fff libiodbc.2.dylib ??? (???) <0e9f71de7fa6cfc5d42a7754d393b22c> /usr/lib/libiodbc.2.dylib
   0x5f5000 - 0x602fff libiodbcinst.2.dylib ??? (???) <f225b96d6bf1d05acdf0208a4ea3eebe> /usr/lib/libiodbcinst.2.dylib
   0x609000 - 0x63cff3 +libogdi.dylib ??? (???) <7e42a75f044a32a941c83ca42b890fa6> /Library/Frameworks/GDAL.framework/Versions/1.5/Libraries/libogdi.dylib
   0x648000 - 0x663ff3 +libpq.dylib ??? (???) <b40a7f353e9cd57551458d1117379bfc> /Library/Frameworks/GDAL.framework/Versions/1.5/Libraries/libpq.dylib
   0x66d000 - 0x698ffb libcurl.4.dylib ??? (???) <54ada27deb3b4ff7043d8836264eca0d> /usr/lib/libcurl.4.dylib
   0xda9000 - 0x16fafec +org.gdal.gdal 1.5.2 (GDAL/OGR 1.5.2-1) <e58c6df3508b079ade47e0ebac7ae34b> /Library/Frameworks/GDAL.framework/Versions/1.5/GDAL
  0x99ef000 - 0x9bd7fff com.apple.RawCamera.bundle 2.0.11 (410) <7704cc57f7daceb81672bfdc4434da40> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
  0xb000000 - 0xb0adfeb com.tcltk.tklibrary 8.4.7 b (8.4.7 b) <9e3b1ff29ce1a8ada6e6354a43f11c5b> /System/Library/Frameworks/Tk.framework/Versions/8.4/Tk
0x1b44b000 - 0x1b5cefe3 GLEngine ??? (???) <bfbd7ce69ea896a6b38d6232b01cdeda> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x1b5fc000 - 0x1b964fe8 com.apple.GeForce8xxxGLDriver 1.5.36 (5.3.6) <e5d9fd7873a13fc3acc278b534337527> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
0x1bc9f000 - 0x1bcbbff7 GLRendererFloat ??? (???) <dcdc2e0de7fb9a52d99e529c3688f26d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x8fe00000 - 0x8fe2db43 dyld 97.1 (???) <100d362e03410f181a34e04e94189ae5> /usr/lib/dyld
0x90003000 - 0x9027efe7 com.apple.Foundation 6.5.7 (677.22) <8fe77b5d15ecdae1240b4cb604fc6d0b> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90293000 - 0x90378ff3 com.apple.CoreData 100.1 (186) <8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x90379000 - 0x904e0ff3 libSystem.B.dylib ??? (???) <d68880dfb1f8becdbdac6928db1510fb> /usr/lib/libSystem.B.dylib
0x904e1000 - 0x9056bfe3 com.apple.DesktopServices 1.4.7 (1.4.7) <d16642ba22c32f67be793ebfbe67ca3a> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9056c000 - 0x906beff3 com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x906bf000 - 0x90752fff com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x90753000 - 0x90df3fff com.apple.CoreGraphics 1.407.2 (???) <3a91d1037afde01d1d8acdf9cd1caa14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90df4000 - 0x90e26fff com.apple.LDAPFramework 1.4.5 (110) <cc04500cf7b6edccc75bb3fe2973f72c> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x90eca000 - 0x90ed6ff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x90f4a000 - 0x90f4affc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x90f4b000 - 0x90f57ffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90f58000 - 0x90f83fe7 libauto.dylib ??? (???) <42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x90fa3000 - 0x91171ff3 com.apple.security 5.0.4 (34102) <55dda7486df4e8e1d61505be16f83a1c> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x911af000 - 0x911b0ffc libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x911e1000 - 0x911e3ff5 libRadiance.dylib ??? (???) <8a844202fcd65662bb9ab25f08c45a62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x913a7000 - 0x913c6ffa libJPEG.dylib ??? (???) <e7eb56555109e23144924cd64aa8daec> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91417000 - 0x91419fff com.apple.securityhi 3.0 (30817) <32d1c581312dbe0c408578df99661f96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9141f000 - 0x9142cfe7 com.apple.opengl 1.5.9 (1.5.9) <7e5048a2677b41098c84045305f42f7f> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9142d000 - 0x91435fff com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91436000 - 0x91436ffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x92410000 - 0x927adfef com.apple.QuartzCore 1.5.7 (1.5.7) <2fed2dd7565c84a0f0c608d41d4d172c> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x92845000 - 0x9285bfff com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9285c000 - 0x928b6ff7 com.apple.CoreText 2.0.3 (???) <1f1a97273753e6cfea86c810d6277680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x928b7000 - 0x9297eff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9297f000 - 0x92a0bff7 com.apple.LaunchServices 290.3 (290.3) <6f9629f4ed1ba3bb313548e6838b2888> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92a0c000 - 0x92a9fff3 com.apple.ApplicationServices.ATS 3.4 (???) <8c51de0ec3deaef416578cd59df38754> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x92aa0000 - 0x9329efef com.apple.AppKit 6.5.6 (949.43) <a3a300499bbe4f1dfebf71d752d01916> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9329f000 - 0x93351ffb libcrypto.0.9.7.dylib ??? (???) <69bc2457aa23f12fa7d052601d48fa29> /usr/lib/libcrypto.0.9.7.dylib
0x93352000 - 0x933afffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x933b0000 - 0x9346afe3 com.apple.CoreServices.OSServices 226.5 (226.5) <2a135d4fb16f4954290f7b72b4111aa3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9346b000 - 0x93486ffb libPng.dylib ??? (???) <4780e979d35aa5ec2cea22678836cea5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x93487000 - 0x934d8ff7 com.apple.HIServices 1.7.0 (???) <01b690d1f376e400ac873105533e39eb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x934f6000 - 0x935a6fff edu.mit.Kerberos 6.0.12 (6.0.12) <685cc018c133668d0d3ac6a1cb63cff9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x93611000 - 0x93621fff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <06d8fc0307314f8ffc16f206ad3dbf44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x93622000 - 0x93646fff libxslt.1.dylib ??? (???) <0a9778d6368ae668826f446878deb99b> /usr/lib/libxslt.1.dylib
0x93647000 - 0x93a05fea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x93abc000 - 0x93acaffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x9411d000 - 0x9412cfff libsasl2.2.dylib ??? (???) <bb7971ca2f609c070f87786a93d1041e> /usr/lib/libsasl2.2.dylib
0x9412d000 - 0x94136fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9439b000 - 0x944e1ff7 com.apple.ImageIO.framework 2.0.4 (2.0.4) <6a6623d3d1a7292b5c3763dcd108b55f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x94514000 - 0x94518fff libGIF.dylib ??? (???) <572a32e46e33be1ec041c5ef5b0341ae> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x94519000 - 0x94529ffc com.apple.LangAnalysis 1.6.4 (1.6.4) <8b7831b5f74a950a56cf2d22a2d436f6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x94598000 - 0x945b6fff libresolv.9.dylib ??? (???) <a8018c42930596593ddf27f7c20fe7af> /usr/lib/libresolv.9.dylib
0x945b7000 - 0x945f8fe7 libRIP.A.dylib ??? (???) <5d0b5af7992e14de017f9a9c7cb05960> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94648000 - 0x94670ff7 com.apple.shortcut 1 (1.0) <057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x94671000 - 0x94671ffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x94672000 - 0x94696feb libssl.0.9.7.dylib ??? (???) <c7359b7ab32b5f8574520746e10a41cc> /usr/lib/libssl.0.9.7.dylib
0x94697000 - 0x94722fff com.apple.framework.IOKit 1.5.1 (???) <f9f5f0d070e197a832d86751e1d44545> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x94723000 - 0x9477cff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x949e6000 - 0x94a65ff5 com.apple.SearchKit 1.2.1 (1.2.1) <3140a605db2abf56b237fa156a08b28b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94a66000 - 0x94a70feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x94a71000 - 0x94a87fe7 com.apple.CoreVideo 1.5.1 (1.5.1) <001910004257f1386724398f584b30b5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94ac2000 - 0x94b3cff8 com.apple.print.framework.PrintCore 5.5.3 (245.3) <222dade7b33b99708b8c09d1303f93fc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x94b3d000 - 0x94b6cfe3 com.apple.AE 402.2 (402.2) <e01596187e91af5d48653920017b8c8e> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x94b6d000 - 0x94bb6fef com.apple.Metadata 10.5.2 (398.25) <e0572f20350523116f23000676122a8d> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x94bb7000 - 0x94bbeffe libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x94bbf000 - 0x94bbfff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x94bcd000 - 0x94c4afeb com.apple.audio.CoreAudio 3.1.1 (3.1.1) <f35477a5e23db0fa43233c37da01ae1c> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x94c4b000 - 0x9511cf3e libGLProgrammability.dylib ??? (???) <5d283543ac844e7c6fa3440ac56cd265> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9511d000 - 0x95123fff com.apple.print.framework.Print 218.0.2 (220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x95169000 - 0x951a3fe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x951a4000 - 0x9547eff3 com.apple.CoreServices.CarbonCore 786.10 (786.10) <ec35bb05f67fe0e828d49dda88bbf6d7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9547f000 - 0x954c1fef com.apple.NavigationServices 3.5.2 (163) <91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x954c2000 - 0x954c7fff com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x954c8000 - 0x954fffff com.apple.SystemConfiguration 1.9.2 (1.9.2) <8b26ebf26a009a098484f1ed01ec499c> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x95505000 - 0x95505ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x95510000 - 0x95528fff com.apple.openscripting 1.2.8 (???) <572c7452d7e740e8948a5ad07a99602b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x95529000 - 0x95661ff7 libicucore.A.dylib ??? (???) <18098dcf431603fe47ee027a60006c85> /usr/lib/libicucore.A.dylib
0x95744000 - 0x95748fff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x95749000 - 0x95b59fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95b5a000 - 0x95bf7ffc com.apple.CFNetwork 422.11 (422.11) <2780dfc3d2186195fccb3634bfb0944b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x95f50000 - 0x95ff7feb com.apple.QD 3.11.54 (???) <b743398c24c38e581a86e91744a2ba6e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x960c2000 - 0x96101fef libTIFF.dylib ??? (???) <3589442575ac77746ae99ecf724f5f87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x961b1000 - 0x961b8ff7 libCGATS.A.dylib ??? (???) <386dce4b28448fb86e33e06ac466f4d8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x962bb000 - 0x96342ff7 libsqlite3.0.dylib ??? (???) <6978bbcca4277d6ae9f042beff643f7d> /usr/lib/libsqlite3.0.dylib
0x96343000 - 0x96424ff7 libxml2.2.dylib ??? (???) <d69560099d9eb32ba7f8a17baa65a28d> /usr/lib/libxml2.2.dylib
0x96425000 - 0x96428fff com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x96429000 - 0x96485ff7 com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x96555000 - 0x9685dfff com.apple.HIToolbox 1.5.4 (???) <3747086ba21ee419708a5cab946c8ba6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9685e000 - 0x96865fe9 libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x96866000 - 0x96946fff libobjc.A.dylib ??? (???) <7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
0x96947000 - 0x96974feb libvDSP.dylib ??? (???) <b232c018ddd040ec4e2c2af632dd497f> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96975000 - 0x9697cfff com.apple.agl 3.0.9 (AGL-3.0.9) <2f39c480cfcee9358a23d61b20a6aa56> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9697d000 - 0x96988fe7 libCSync.A.dylib ??? (???) <e6aceed359bd228f42bc1246af5919c9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9699d000 - 0x9699dfff com.apple.Carbon 136 (136) <7f03616ee9261fb42dc6e6dd77a6f01c> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9699e000 - 0x969dcff7 libGLImage.dylib ??? (???) <1123b8a48bcbe9cc7aa8dd8e1a214a66> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x96ba9000 - 0x96bbeffb com.apple.ImageCapture 5.0.1 (5.0.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x96d45000 - 0x96dc2fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x96dc3000 - 0x96e8efff com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x96e8f000 - 0x96f83ff4 libiconv.2.dylib ??? (???) <c508c60fafca17824c0017b2e4369802> /usr/lib/libiconv.2.dylib
0x96f84000 - 0x96f84ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96f85000 - 0x96fadfff libcups.2.dylib ??? (???) <81abd305142ad1b771024eb4a1309e2e> /usr/lib/libcups.2.dylib
0x96fae000 - 0x970e1fff com.apple.CoreFoundation 6.5.5 (476.17) <4a70c8dbb582118e31412c53dc1f407f> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x970e2000 - 0x970e2ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
Binary Images:
This problem again - it's linking the system tcltk 8.4.
There's a note to the OSX source readme to symlink the ActiveTcl framework to /usr/local. This should avoid accidental system tcltk linking:
sudo ln -sf /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl /usr/local/lib/libtcl.dylib
sudo ln -sf /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl /usr/local/lib/libtcl8.5.dylib
sudo ln -sf /Library/Frameworks/Tcl.framework/Versions/8.5/libtclstub8.5.a /usr/local/lib/libtclstub8.5.a
sudo ln -sf /Library/Frameworks/Tk.framework/Versions/8.5/Tk /usr/local/lib/libtk.dylib
sudo ln -sf /Library/Frameworks/Tk.framework/Versions/8.5/Tk /usr/local/lib/libtk8.5.dylib
sudo ln -sf /Library/Frameworks/Tk.framework/Versions/8.5/libtkstub8.5.a /usr/local/lib/libtkstub8.5.a
sudo ln -sf tclsh8.5 /usr/local/bin/tclsh
sudo ln -sf wish8.5 /usr/local/bin/wish
(I added the tclsh and wish symlinks recently, haven't comitted yet, to help get the GUI to use 8.5)
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
