On Dec 20, 2008, at 10:00 AM, <grass-dev-request@lists.osgeo.org> <grass-dev-request@lists.osgeo.org > wrote:
Date: Sat, 20 Dec 2008 10:42:40 -0600
Subject: Re: [GRASS-dev] NVIZ problem on Mac
To: Michael Barton <michael.barton@asu.edu>
Cc: grass developers <grass-dev@lists.osgeo.org>
Message-ID: <AEFEE6DF-DA05-4949-B476-0DF87BC3EBB3@kyngchaos.com>
Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yesOn Dec 20, 2008, at 12:32 AM, Michael Barton wrote:
On Dec 19, 2008, at 10:34 PM, William Kyngesburye wrote:
I think this must be a problem with OS X. Both a version compiled
last week and a version compiled in September, in which NVIZ *did*
work now fail. I'll copy the Mac error report below. I am running
10.5.6 now. I have tried this against a self-compiled TclTk aqua
and the ActiveStates version....
Binary Images:
0xa1000 - 0x11ffef com.tcltk.tcllibrary 8.4.7 b (8.4.7 b)
<fd41897f36de9271d601298eaf7cdf4b> /System/Library/Frameworks/
Tcl.framework/Versions/8.4/Tcl...
0xb000000 - 0xb0adfeb com.tcltk.tklibrary 8.4.7 b (8.4.7 b)
<9e3b1ff29ce1a8ada6e6354a43f11c5b> /System/Library/Frameworks/
Tk.framework/Versions/8.4/TkThis problem again - it's linking the system tcltk 8.4.
There's a note to the OSX source readme to symlink the ActiveTcl
framework to /usr/local. This should avoid accidental system tcltk
linking:sudo ln -sf /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl /usr/
local/lib/libtcl.dylib
local/lib/libtcl8.5.dylib
libtclstub8.5.a /usr/local/lib/libtclstub8.5.a
sudo ln -sf /Library/Frameworks/Tk.framework/Versions/8.5/Tk /usr/
local/lib/libtk.dylib
local/lib/libtk8.5.dylib
libtkstub8.5.a /usr/local/lib/libtkstub8.5.a
sudo ln -sf tclsh8.5 /usr/local/bin/tclsh
sudo ln -sf wish8.5 /usr/local/bin/wish(I added the tclsh and wish symlinks recently, haven't comitted yet,
to help get the GUI to use 8.5)-----
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Thanks for troubleshooting this William.
I can't figure out why this is trying to use the system TclTk when 1) it was compiled against 8.5, 2) GRASS_WISH is set to wish8.5 so that all the *rest* of the GUI uses 8.5 instead of 8.4, and 3) the same version that worked fine a few weeks ago stopped working.
Michael
