[GRASS-dev] nvizlib compile error
I get an error trying to compile lib/nviz on a Debian system with a fresh SVN checkout of trunk:
"~/SRC/GRASS/grass_trunk/lib/nviz$ make
gcc -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -Wall -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I/usr/include -DPACKAGE=\""grasslibs"\" -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -o OBJ.i486-pc-linux-gnu/cplanes_obj.o -c cplanes_obj.c
In file included from cplanes_obj.c:19:
/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include/grass/nviz.h:31:4: error: #error Unsupported platform, or confused platform defines...
/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include/grass/nviz.h:113: error: expected specifier-qualifier-list before ‘Display’
make: *** [OBJ.i486-pc-linux-gnu/cplanes_obj.o] Erreur 1"
- configure output shows:
checking for location of OpenGL library...
checking for glBegin in -lGL... yes
checking for gluBeginCurve in -lGLU... yes
checking for glXCreatePbuffer... yes
checking for glXCreateGLXPixmap... yes
OpenGL support: yes
Moritz
2008/7/8 Moritz Lennert <mlennert@club.worldonline.be>:
error: expected specifier-qualifier-list before 'Display'
OpenGL support: yes
should be fixed,
http://trac.osgeo.org/grass/changeset/32051
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
On 08/07/08 19:41, Martin Landa wrote:
OpenGL support: yes
should be fixed,
Now it compiles, but when I display the elevation map from the NC data set and then chose the nviz tool in the map display, the entire wx gui crashes...
Just found out why: it's a locale problem. LANG is set to fr_BE.UTF-8 on my system. When I set it to C nviz runs (great job !!), but when I leave the default setting, wxgrass crashes and I get the following error in the terminal window where I launch g.gui:
GRASS_INFO_ERROR(22238,1): région pour le jeu de données (mapset) courant ligne 1: <n-s resol: 29.349241>
GRASS_INFO_ERROR(22238,1): lancer "g.region"
GRASS_INFO_END(22238,1)
Moritz
crashes...
right, it crashes when LC_NUMERIC != "C", calling G_scan_resolution()
http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/rd_cellhd.c#L258
quick fix
http://trac.osgeo.org/grass/changeset/32063
Martin
> crashes...
LC_NUMERIC affects the format which scanf("%f") etc understands. If
it's set to a locale which uses a comma as the decimal separator, any
GRASS function which tries to read floating-point values which use a
period (i.e. many of GRASS' internal file formats) will fail.
This isn't a problem for normal GRASS modules, as GRASS modules (and
library functions) never call setlocale(LC_NUMERIC). It is a problem
if you're using GRASS library functions from within a program which
sets LC_NUMERIC from the environment (I suspect that this includes the
Python interpreter).
quick fix
A more general fix would be to call setlocale(LC_NUMERIC,"C") from
e.g. gisinit() (in lib/gis/gisinit.c). Otherwise, we will probably end
up running into this issue repeatedly.
2008/7/10 Glynn Clements <glynn@gclements.plus.com>:
quick fix
done
http://trac.osgeo.org/grass/changeset/32078
and
http://trac.osgeo.org/grass/changeset/32079
M.
