I’ve seen that the grass.script.core.percent() module method wraps the g.message -p command.
It’s ok when the work is done within the python code, but how to grab the progress emitted by a GRASS command (i,e, G_percent)?
There are many ways to run a command from python. What is the most appropriate to obtain/pipe the percentage from the command… given it can be done?
giovanni
http://grass.osgeo.org/programming7/percent_8c.html
http://grass.osgeo.org/programming7/namespacepython_1_1core.html#a14ce86fd0c5c18da189e6e3d0cc10501
G. Allegri wrote:
I've seen that the grass.script.core.percent() module method wraps the
It's ok when the work is done within the python code, but how to grab the
appropriate to obtain/pipe the percentage from the command... given it can
be done?
If you want to parse the output, set GRASS_MESSAGE_FORMAT=gui in the
environment when running the command and read from the command's
stderr; e.g.
import grass.script as grass
env = os.environ.copy()
env['GRASS_MESSAGE_FORMAT'] = 'gui'
p = grass.start_command(..., stderr = grass.PIPE, env = env)
# read from p.stderr
p.wait()
If you need to capture both stdout and stderr, you need to use
threads, select, or non-blocking I/O to consume data from both streams
as it is generated in order to avoid deadlock.
On Thu, Dec 1, 2011 at 7:57 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
stderr; e.g.
import grass\.script as grass
env = os\.environ\.copy\(\)
env\['GRASS\_MESSAGE\_FORMAT'\] = 'gui'
p = grass\.start\_command\(\.\.\., stderr = grass\.PIPE, env = env\)
\# read from p\.stderr
p\.wait\(\)
Thanks, added to
http://grass.osgeo.org/wiki/GRASS_and_Python#Percentage_output_for_progress_of_computation
Thanks very much!
giovanni
2011/12/1 Markus Neteler <neteler@osgeo.org>
environment when running the command and read from the command’s
stderr; e.g.
env[‘GRASS_MESSAGE_FORMAT’] = ‘gui’
p = grass.start_command(…, stderr = grass.PIPE, env = env)
read from p.stderr
p.wait()
Thanks, added to
p.wait()
Or: redirect both stdout and stderr to the same pipe (and hope that
the normal output doesn't include anything which will be mistaken for
progress/error/etc messages):
p = grass.start_command(..., stdout = grass.PIPE, stderr = grass.STDOUT, env = env)
