Giovanni wrote:
I've seen that the grass.script.core.percent() module method wraps
the g.message -p command.It's ok when the work is done within the python
code, but how to grab the progress emitted by a GRASS command (i,e,
G_percent)?
There are many ways to run a command from python. What is the most
appropriate to obtain/pipe the percentage from the command... given it
can be done?
try the GRASS_MESSAGE_FORMAT=gui environment variable.
see http://grass.osgeo.org/grass70/manuals/html70_user/variables.html#enviro
Hamish
