[GRASS-dev] odd configure error on MacOS X
I've been compiling GRASS with William's frameworks and have had no problems with configuring and compiling for cairo. I'm including my config string below.
However, displays will not render using cairo in GRASS 6.x. They will render in GRASS 7.
Michael
./configure --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications/GRASS --enable-macosx-app --with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.0/bin/wx-config --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386 x86_64"
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 29, 2011, at 3:09 PM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Fri, 29 Jul 2011 08:19:11 -0500
Subject: Re: [GRASS-dev] odd configure error on MacOS X
To: Dylan Beaudette <dylan.beaudette@gmail.com>
Cc: grass developers <grass-dev@lists.osgeo.org>
Message-ID: <FC1592CA-19E0-4BF2-82D2-F95C109B6711@kyngchaos.com>
Content-Type: text/plain; charset=us-ascii
On Jul 29, 2011, at 3:41 AM, Dylan Beaudette wrote:
It seems more complicated that I thought. After fixing the includes,
to use the KingChaos Frameworks, recompiling results in:
In file included from Graph.c:19:
/Library/Frameworks/cairo.framework/unix/include/cairo/cairo-svg.h:79:3:
error: #error Cairo was not compiled with support for the svg backend
make: *** [OBJ.i386-apple-darwin9.8.0/Graph.o] Error 1
Can SVG be disabled somehow?
Dylan
Odd, my cairo framework svg support. cairo-features.h has:
#define CAIRO_HAS_SVG_SURFACE 1
FYI, I configure GRASS for my cairo framework with (note the *2* include dirs):
--with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" \
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
