On Oct 15, 2009, at 3:40 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Thu, 15 Oct 2009 11:09:11 +0200
Subject: [GRASS-dev] OGR write access
To: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID:
<f8fe65c40910150209v49be8404xe616a7dc9922c323@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
I am thinking how to implement direct write access to OGR datasources
from the user point of view. One approach would be to implement global
flag '--u' for updating existing vector map (i.e. OGR datasource).
E.g.
v.out.ogr input=test dsn=. type=point -n
v.external dsn=. layer=test output=test
v.random out=test n=1000 --u
this could work also for native format
v.edit map=test tool=create
Or to add new parameters 'dns/format' which would be used only for OGR
format, not for the native one.
v.random out=test n=1000 format=ESRI_Shapefile dns=.
Any ideas?
Martin
Might this be worth considering integrating with the data catalog mentioned yesterday?
http://lists.osgeo.org/pipermail/grass-gui/2009-October/000679.html
Michael
2009/10/15 Michael Barton <michael.barton@asu.edu>:
yesterday?
I see this as separate issue. First step to implemented it in the
GRASS libraries and for CLI. Integration into wxGUI can come later.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Fair enough. Better to do this one step at a time.
Michael
On Oct 15, 2009, at 8:58 AM, Martin Landa wrote:
yesterday?
[GRASS-GUI] DataCatalog
Martin
2009/10/15 Michael Barton <Michael.Barton@asu.edu>:
sorry, I don't understand right now. Without direct OGR write support
in the GRASS libraries and the GRASS modules you can work on the GUI
integration. GRASS libraries and modules need to be updated first.
Martin
On Oct 15, 2009, at 11:36 AM, Martin Landa wrote:
Martin
I was agreeing with you.
Michael
sorry, I misunderstood. Martin
