[GRASS-dev] ogsf, nviz, m.nviz.image build errors -- ticket #1423 ?
Hi!
In Ubuntu 13.04, as you probably know, ogsf, nviz and m.nviz.image
(still) wont compile. This all is related to ticket
<https://trac.osgeo.org/grass/ticket/1423&gt; I guess.
GRASS GIS 7.0.svn 56732 compilation log
Started compilation: Sun Jun 16 19:13:04 EEST 2013
Errors in:
/geo/osgeo/src/grass_trunk/lib/ogsf
/geo/osgeo/src/grass_trunk/lib/nviz
/geo/osgeo/src/grass_trunk/misc/m.nviz.image
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order
they
appear in the error log. If you get an error building a library, you
will
also get errors from anything which uses the library.
Finished compilation: Sun Jun 16 19:31:30 EEST 2013
make: *** [default] Error 1
Nikos
On Sunday 16 of June 2013 20:21:12 Nikos Alexandris wrote:
Hi!
Errors in:
run
'make'.
they
will
Same (almost) for grass64:
GRASS GIS compilation log
Started compilation: Sun Jun 16 20:24:02 EEST 2013
Errors in:
/geo/osgeo/src/grass64_release/lib/ogsf
/geo/osgeo/src/grass64_release/lib/nviz
/geo/osgeo/src/grass64_release/misc/m.nviz.image
/geo/osgeo/src/grass64_release/visualization/xganim
/geo/osgeo/src/grass64_release/visualization/nviz
'make'.
they
will
Finished compilation: Sun Jun 16 20:32:53 EEST 2013
Nikos
i'm on ubuntu 13.04 as well
grass_trunk configured with :
./configure --with-freetype-includes=/usr/include/freetype2 --with-blas --with-netcdf --with-geos --with-lapack --with-odbc --with-pthread --with-readline --with-sqlite --with-wxwidgets --with-postgres-includes=/usr/include/postgresql --with-postgres
wx is 2.8 :
wx-config --version-full
2.8.12.1
i do not have errors to build ogsf/nviz/m.nviz.image
the only error i got are in
wximgview/xganim
i guess because of wx-2.8
attached the log :
https://gist.github.com/5793126
Massimo.
Il giorno 16/giu/2013, alle ore 13:35, Nikos Alexandris <nik@nikosalexandris.net> ha scritto:
Hi!
Errors in:
run
'make'.
they
will
Errors in:
'make'.
they
will
Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
(didn't)
ogsf, nviz and m.nviz.image(still) wont compile.
AFAIK right now --with-ffmpeg adds nothing in GRASS 7 since
it was only used by Tcl/Tk NVIZ and that got deleted in trunk.
We need to consider if we should keep direct animation creation
support for wxGUI; I'm happy with producing raw PPM frames and
ffmpeg API is a pain to try and keep up with, but I'll reserve
judgement until we see what the less-changing libav looks like.
--with-ffmpeg --with-ffmpeg-includes="/usr/include/libavcodec /usr/include/libavformat /usr/include/libswscale /usr/include/libavutil"
Massimo:
wximgview/xganim
attached the log :
Errors in:
/home/epi/dev/src/grass7_trunk/visualization/wximgview
/home/epi/dev/src/grass7_trunk/visualization/xganim
c++ -g -O2 -I/home/epi/dev/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
-I/usr/lib/x86_64-linux-gnu/wx/include/base-unicode-release-2.8
-I/usr/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -DwxUSE_GUI=0
-pthread -DWXINTL_NO_GETTEXT_MACRO -DPACKAGE=\""grassmods"\"
-o OBJ.x86_64-unknown-linux-gnu/main.o -c main.cpp
In file included from main.cpp:41:0:
wximgview.h:9:23: error: invalid use of incomplete type 'class wxFrame'
In file included from /usr/include/wx-2.8/wx/wx.h:27:0,
from main.cpp:34:
/usr/include/wx-2.8/wx/utils.h:50:28: error: forward declaration of 'class wxFrame'
wximgview.h:12:5: error: 'wxTimer' does not name a type
wximgview.h:19:19: error: 'wxSize' does not name a type
wximgview.h:19:27: error: ISO C++ forbids declaration of 'size' with no type [-fpermissive]
wximgview.h:23:17: error: 'wxPaintEvent' has not been declared
epi@epi:~/dev/src/grass7_trunk/visualization/wximgview$ cd /home/epi/dev/src/grass7_trunk/visualization/xganim
epi@epi:~/dev/src/grass7_trunk/visualization/xganim$ make
-I/usr/lib/x86_64-linux-gnu/wx/include/base-unicode-release-2.8 -I/usr/include/wx-2.8
-D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -DwxUSE_GUI=0 -pthread -DWXINTL_NO_GETTEXT_MACRO
-DPACKAGE=\""grassmods"\" -I/home/epi/dev/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
-o OBJ.x86_64-unknown-linux-gnu/gui.o -c gui.cpp
In file included from /usr/include/wx-2.8/wx/window.h:23:0,
from /usr/include/wx-2.8/wx/sizer.h:17,
from gui.cpp:23:
/usr/include/wx-2.8/wx/cursor.h: In constructor 'wxBusyCursorSuspender::wxBusyCursorSuspender()':
/usr/include/wx-2.8/wx/cursor.h:65:22: error: 'wxIsBusy' was not declared in this scope
/usr/include/wx-2.8/wx/cursor.h:67:26: error: 'wxBusyCursor' has not been declared
/usr/include/wx-2.8/wx/cursor.h: In destructor 'wxBusyCursorSuspender::~wxBusyCursorSuspender()':
/usr/include/wx-2.8/wx/cursor.h:72:22: error: 'wxIsBusy' was not declared in this scope
fwiw as a pre-release test I built the 6.4.3svn Debian
package yesterday in Debian/sid (wx2.8), it was all ok.
I'll try in a ubuntu 13.04 vm..
Hamish
Hamish wrote:
(didn't)
sorry :-/
I don't mind about ffmpeg for animation creation -- hopefully most people wont
mind too. What "hurts" more is nviz not working, which means, literally no 3D-
mode available in wxGUI (right?).
Massimo:
> wximgview/xganim
strange, I do have
wx-config --version
2.8.12
but xganim compiled fine!
Nikos
> attached the log :
> Errors in:
> c++ -g -O2
> -I/home/epi/dev/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/include>
> from main.cpp:34:
> wxFrame' In file included from main.cpp:41:0:
> type [-fpermissive] wximgview.h:23:17: error: 'wxPaintEvent' has not been
> declared
> c++ -g -O2
>-I/home/epi/dev/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/include -o
> from gui.cpp:23:
> in this scope /usr/include/wx-2.8/wx/cursor.h:67:26: error:
> 'wxBusyCursor' has not been declared /usr/include/wx-2.8/wx/cursor.h: In
> in this scope
No errors now! I was missing the last lib (/usr/include/libavutil) in my
configuration script. Currently it goes like:
CFLAGS="-ggdb -march=native -Wall -Werror-implicit-function-declaration" \
./configure \
--with-cxx \
--with-proj-share=/usr/local/share/proj/ \
--with-geos=/usr/local/bin/geos-config \
--with-motif \
--with-tcltk-includes="/usr/include/tcl8.5/" \
--with-cairo \
--with-opengl-libs=/usr/include/GL \
--with-python=yes --with-python=/usr/bin/python2.7-config \
--with-wxwidgets \
--with-ffmpeg=yes --with-ffmpeg-includes="/usr/include/libavcodec
/usr/include/libavformat /usr/include/libswscale /usr/include/libavutil" \
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
--with-odbc=yes \
--with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
--with-sqlite=yes \
--with-postgres=yes --with-postgresql=yes --with-postgres-
includes="/usr/include/postgresql" \
--with-openmp --with-pthread \
--with-readline \
--with-nls \
--enable-largefile=yes \
--with-netcdf
Thanks, N :slight_smile:
2013/6/16 Nikos Alexandris <nik@nikosalexandris.net>:
these headers should be checked by configuration script I would say. Martin
Martin
afaik they (generally) are, it's just that the functions keep on
getting renamed and jumping between libs, so it's a moving target,
and it's a bit much to do a test compile for every function call
used.
regards,
Hamish
