Dear all,
I want to integrate the "AHPF" fusion algorithm, <i.fusion.hpf> [0], into <i.pansharpen> [1]. And I need some assistance.
1. <i.pansharpen> has the following, simple, interface:
i.pansharpen [-sl] red=name green=name blue=name pan=name
output=basename method=value [--overwrite] [--help] [--verbose]
[--quiet] [--ui]
plus
Flags:
-s Serial processing rather than parallel processing
-l Rebalance blue channel for LANDSAT
while the HPF implementation looks like:
i.fusion.hpf [-l2c] pan=filename msx=filename(s)[,filename(s),...]
outputsuffix=suffix string [ratio=rational number] [center=string]
[center2=string] [modulation=string] [modulation2=string]
[trim=rational number] [--overwrite] [--help] [--verbose] [--quiet]
[--ui]
plus
Flags:
-l Linearly match histogram of Pan-sharpened output to Multi-Spectral input
-2 2-Pass Processing (recommended) for large resolution ratio (>=5.5)
-c Match color table of Pan-Sharpened output to Multi-Spectral input
While the first module appears to be simple and straightforward, it has its limitations (rgb required, underlying ihs method restricted to 8-bit data). The second module appears complex, but it works right away by simply feeding a pan and a multi-spectral band (or bands) and, offers many fine-tuning options.
2. <i.pansharpen> has the R-G-B logic hardcoded (one pan and three multi-spectral bands required), while <i.fusion.hpf> will work simply with a pan and only one or any number of multiple low-resolution bands.
If all of the fine-tuning options for HPF will be merged into i.pansharpen, it'll get "heavy" and complex. I am asking for help to design the integration (not for the actual coding). Any ideas?
Thank you, Nikos
[0] <https://github.com/NikosAlexandris/i.fusion.hpf>
[1] <http://grass.osgeo.org/grass70/manuals/i.pansharpen.html>
