[GRASS-dev] option "Set computational region from display extent " + v.in.region produce unexpected result
I set the computational region using the option "Set computational region from display extent " from wxgui and after that I run v.in.region. The result doesn’t match the region that I chose. Could anyone try to reproduce that?
(G6.4.3)
Thanks
Best regards,
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
