[GRASS-dev] options for scripts
Potentially, are all the options listed in parser_standard_options.c available to be used and parsed in scripts as well as in C modules?
I just tried 3. Two worked and one didn't. So I'm wondering which is the fluke--the options for database table name and database columns working or the one for database driver not working (actually it partly worked in that the wxPython menuform.py generated the correct control, but it lacked the list of drivers to populate it)?
If all those in parser_standard_options.c CAN be used in scripts, then it is useful to update the scripting guidelines to indicate this.
Michael
I'm not sure what you're asking.
The G_OPT_* constants are only meaningful to
G_define_standard_option(), which can only be used from C.
