Paulo van Breugel wrote:
> In the addon r.forestfrag (python script), I used os.remove() to
> remove some temporary files (in lines 230, 258 and 430). However, this
> fails in Windows, with an error message like below:
> WindowsError: [Error 32] The process cannot access the file because it
> is being used by another process:
> 'c:\\users\\uqdshana\\appdata\\local\\temp\\tmpwlv54l'
> Removing these lines with os.remove() solves the problem, but than the
> user is left with these temporary files. Is there a Window compatible
> way to remove them in the script?
Perhaps I should have looked harder first, the underlying problem
(described here: https://www.logilab.org/blogentry/17873) seems to be
that the file needs to be closed at OS level, which can be done using
os.close().
Ideally, files should be handled using context managers and "with".
Python's own file objects are already context managers, so you can use
e.g.
with open(filename) as f:
data = f.read()
# by this point, f has already been closed
For dealing with OS-level descriptors, you can use contextlib (Python
2.5+) to easily create context managers, e.g.
import os
import tempfile
from contextlib import contextmanager
@contextmanager
def temp():
fd, filename = tempfile.mkstemp()
try:
yield (fd, filename)
finally:
os.close(fd)
os.remove(filename)
if __name__ == '__main__': ...
with temp() as (fd, filename):
whatever()
# fd has been closed and the file removed
Use of "with" ensures that clean-up happens in the event of an
exception or other forms of early exit (e.g. return, break, continue).
