On Mon, Feb 26, 2018 at 1:33 AM, Markus Neteler <neteler@osgeo.org> wrote:
On Mon, Feb 26, 2018 at 5:16 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
it seems that there is some issue with authentication for Subversion. When I
try to download source code using svn checkout
I get “Authentication
realm: <https://svn.osgeo.org:443> OSGeo Login”. This was observed on two
computers with Ubuntu and I can reproduce that in Docker:
docker run -it --rm ubuntu
A trunk/lib/raster3d/test/test_raster3d_lib.h
Authentication realm: <https://svn.osgeo.org:443> OSGeo Login
Password for ‘root’:
Why should it request that at all? You can anonymously checkout the
code, can’t you?
You should be able, but that’s what I can’t do.
I just updated all my OSGeo SVN repos I am following, no problem at all.
Do you mean on your computer where you entered credentials in past to get write access? That would be the difference. The two computers I mentioned were a fresh install without someone’s credentials as well as the Docker test.
Another test, on Fedora 27:
[mneteler@oboe ~ ]$ mkdir bla
[mneteler@oboe ~ ]$ cd bla
[mneteler@oboe bla ]$ svn co https://svn.osgeo.org/grass/grass-promo
A grass-promo/grasslogo
A grass-promo/screenshots
A grass-promo/screenshots/wxpython
A grass-promo/screenshots/wxpython/location_wizard
A grass-promo/screenshots/wxpython/general
A grass-promo/screenshots/wxpython/digitization
A grass-promo/grassflyer
A grass-promo/grassflyer/flyer1
A grass-promo/grassflyer/flyer1/es
A grass-promo/grasslogo/ascii_logo_bold.svg
A grass-promo/screenshots/wxpython/digitization/digit-gism.png
It does not ask me to accept the certificate nor should it (IMHO)!
It says “The certificate is not issued by a trusted authority”. After accepting permanently, it does not ask again as expected.
Maybe some local issue at your end with the certificate introducing
other troubles?
No idea, seems independent, but appeared at a similar time (the certificate issue may not happen outside of Docker, not sure).
Or, it was a temporary problem?
I can’t try the other computers now, but in Docker, I still get the same result:
apt update -y
apt install -y subversion
svn checkout https://svn.osgeo.org/grass/grass/trunk
Error validating server certificate for ‘https://svn.osgeo.org:443’:
- The certificate is not issued by a trusted authority. Use the
fingerprint to validate the certificate manually!
Certificate information:
- Hostname: *.osgeo.org
- Valid: from Apr 28 00:00:00 2016 GMT until May 1 23:59:59 2019 GMT
- Issuer: SSL.com DV CA, www.ssl.com, SSL.com, US
- Fingerprint: 56:50:0D:63:0F:47:10:92:7A:3A:B5:A9:83:F8:97:92:FE:D6:19:95
(R)eject, accept (t)emporarily or accept (p)ermanently?
A trunk/misc/m.measure/main.c
A trunk/misc/m.cogo/TODO
A trunk/misc/m.cogo/Makefile
A trunk/testsuite/vector/v.in.gps_test.sh
A trunk/testsuite/Makefile
A trunk/testsuite/README
