[GRASS-dev] osgeo4w on Windows Vista: g.proj.exe crashes when setting the initial location
On Mar 10, 2009, at 2:26 PM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Tue, 10 Mar 2009 18:00:18 +0000 (GMT)
Subject: Re: [GRASS-dev] osgeo4w on Windows Vista: g.proj.exe crashes
To: "G. Allegri" <giohappy@gmail.com>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID: <Pine.LNX.4.62.0903101758550.10856@vortex.ukshells.co.uk>
Content-Type: TEXT/PLAIN; charset=US-ASCII; format=flowed
On Tue, 10 Mar 2009, G. Allegri wrote:
Hello list.
I've just setup grass from osgeo4w. I'm a Linux user but I need to
develop some grass scripts on windows.
When launching it from grass64.bat as tcltk iface, I obtain the
classic prompt for location. I try to set it from EPSG codes but when
I've choosen the name and the code, g.proj.exe crashes with a
"segmentation violation"
I'm working on Windows Vista SP1.
Can you give an example g.proj command-line that reproduces the problem?
Do other uses of g.proj also crash?
Paul
Paul et al,
I've had reason to create locations from EPSG codes as of yesterday in the OSGEO4W GRASS 6.4RC3. It works fine in XP. I suspect that this is another Vista issue.
Michael
