hi,
tested with osgeo4w-wingrass7 and a SRTM-based ll-location:
r.stream.order streams=gear150@rstreamanalysis dirs=geafd150@rstreamanalysis
elevation=srtemgeahydrodem@rstream accum=srtemgeahydrodemaccum@rstream
vector=gear150rorderv strahler=gear150strahler horton=gear150horton
shreve=gear150shreve hack=gear150hack topo=gear150topodim memory=500
ALL IN RAM CALCULATION
Reading map <gear150@rstreamanalysis>
Reading map <geafd150@rstreamanalysis>
dbmi: Protocol error <= !!!
Finding nodes...
Finding longest streams...
WARNING: Cannot inset new row: insert into gear150rorderv values( 209, 209,
2757, 198 ,183, 0, 2, 2, 2, 4, 458,4, 2, 2659.704775, 2255.083535,
1.179426,2850.005117, 425.856341, 465822.812315, 2745.000000,
2163.000000,601.000000,19.000000, 0.225965)
maybe related to trac.osgeo.org/grass/ticket/1796?
any idea
r.stream.order.txt
<http://osgeo-org.1560.n6.nabble.com/file/n5018538/r.stream.order.txt>
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/osgeo4w-wingrass-7-r-stream-order-addon-tp5018538.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
