there were quite a lot changes lately in the OSGeo4W environment.
trying to start the long installed GRASS 7.4.1
C:\>Traceback (most recent call last):
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\wxgui.py", line 167,
in <module>
sys.exit(main())
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\wxgui.py", line 154,
in main
app = GMApp(workspaceFile)
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\wxgui.py", line 48,
in __init__
wx.App.__init__(self, False)
File
"C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
line 7981, in __init__
self._BootstrapApp()
File
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\wxgui.py", line 99,
in OnInit
from lmgr.frame import GMFrame
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\lmgr\frame.py", line
50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\lmgr\layertree.py",
line 38, in <module>
from mapdisp.frame import MapFrame
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\mapdisp\frame.py",
line 33, in <module>
from mapdisp.toolbars import MapToolbar, NvizIcons
File
"C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\mapdisp\toolbars.py", line
22, in <module>
from nviz.main import haveNviz
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\main.py", line
24, in <module>
from nviz import mapwindow
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\mapwindow.py",
line 42, in <module>
from nviz.workspace import NvizSettings
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\workspace.py",
line 23, in <module>
from nviz import wxnviz
File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\wxnviz.py",
line 45, in <module>
from grass.lib.raster3d import *
File
"C:\OSGEO4~1\apps\grass\grass-7.4.1\etc\python\grass\lib\raster3d.py", line
23, in <module>
_libs["grass_g3d.7.4.1"] = load_library("grass_g3d.7.4.1")
File
"C:\OSGEO4~1\apps\grass\grass-7.4.1\etc\python\grass\lib\ctypes_loader.py",
line 62, in load_library
return self.load(path)
File
line 240, in load
return _WindowsLibrary(path)
File
line 223, in __init__
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:\OSGEO4~1\apps\Python27\lib\ctypes\__init__.py", line 444, in
LoadLibrary
return self._dlltype(name)
File "C:\OSGEO4~1\apps\Python27\lib\ctypes\__init__.py", line 366, in
__init__
self._handle = _dlopen(self._name, mode)
WindowsError: [Error 193] %1 ist keine zulõssige Win32-Anwendung
starting GRASS 7.7.svn
C:\>wxnviz.py: [Error 193] %1 ist keine zulõssige Win32-Anwendung
wxdigit.py: [Error 193] %1 ist keine zulõssige Win32-Anwendung
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\wxgui.py", line
169, in <module>
sys.exit(main())
156, in main
50, in __init__
File
File
103, in OnInit
workspace=self.workspaceFile)
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\lmgr\frame.py",
line 143, in __init__
self.notebook = self._createNoteBook()
line 338, in _createNoteBook
gcstyle=GC_PROMPT)
File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\gui_core\goutput.py",
line 119, in __init__
self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\gui_core\prompt.py", line
139, in __init__
GPrompt.__init__(self, parent=parent, menuModel=menuModel)
File
57, in __init__
self.mapList = self._getListOfMaps()
File
101, in _getListOfMaps
result['raster'] = grass.list_strings('raster')
File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\etc\python\grass\script\core.py", line
1296, in list_strings
mapset=mapset).splitlines():
File
511, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File
351, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None g.list--q-mtype=raster
ended with error
Process ended with non-zero return code -1073741701. See errors in the
(error) output.
C:\>g.version -g
version=7.7.svn
date=2018
revision=r73564
build_date=2018-10-17
build_platform=x86_64-w64-mingw32
build_off_t_size=8
any idea?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
