[GRASS-dev] OSGeo4W-winGRASS - using bash in console - scripts not working
just tested following here with [1]:
- OSGeo4W-winGRASS-console: starting bash:
C:\>bash
GRASS 7.4.2>
- to see if env var are still there, e.g.
GRASS 7.4.2> echo $GRASS_PYTHON
C:\OSGEO4~1\bin\python.exe
the variables set beforehand are still there
- starting a binary grass module there:
GRASS 7.4.2> g.region --help
Manages the boundary definitions for the geographic region.
Usage:
g.region [-dsplectwmn3bgfau] [region=name] [raster=name[,name,...]]
   [raster_3d=name] [vector=name[,name,...]] [n=value] [s=value]
   [e=value] [w=value] [t=value] [b=value] [rows=value] [cols=value]
or
just starts the GUI
- try to start a script module, e.g. r.reclass.area
GRASS 7.4.2> r.reclass.area.bat
/c/OSGEO4~1/apps/grass/grass-7.4.2/bin/r.reclass.area.bat: line 1:
@%GRASS_PYTHON%: command not found
it seems %GRASS_PYTHON%, or in the sense of bash $GRASS_PYTHON, seems not to
be expanded while running bash.
any idea how to get the script modules working?
[1]
System Info
GRASS version: 7.4.2
GRASS SVN revision: r73591
Build date: 2018-10-23
Build platform: x86_64-w64-mingw32
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17134 (OSGeo4W)
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
On Wed, Oct 24, 2018 at 7:26 PM Helmut Kudrnovsky <hellik@web.de> wrote:
C:\>bash
GRASS 7.4.2>
Usage:
or
just starts the GUI
Is there really a "@" char at first character?
Can you try to remove the @ if it is there? I guess it shouldn't...
[1]
System Info
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
best regards
Helmut
Hi Helmut,
Looks like bash doesn't know that it should run batch files with cmd.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
(attachments)
Pflichtangaben (206 Bytes)
Hi devs,
So, is this problem fixable? Where should I report this error to be able to run “all” grass commands and use bash-like for loops, env var setting, back ticks and so on when teaching GRASS to windows users while not being one?
thanks much in advance
Vero
El lun., 29 oct. 2018 a las 9:03, Jürgen E. Fischer (<jef@norbit.de>) escribió:
Hi Helmut,
Looks like bash doesn’t know that it should run batch files with cmd.
Jürgen
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
