[GRASS-dev] OSGeo4W winGRASS77svn: TypeError: endswith first arg must be bytes or a tuple of bytes, not str
just tried to start the latest OSGeo4W winGRASS77svn daily build:
C:\>grass77svn
Starting GRASS GIS...
  File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\gis_set.py", line 34, in
<module>
    from core import globalvar
  File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\globalvar.py", line
35, in <module>
    from core.debug import Debug
  File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line 77,
in <module>
    Debug = DebugMsg()
  File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line 39,
in __init__
    self.SetLevel()
  File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line 45,
in SetLevel
    self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
  File "C:\OSGEO4~1\apps\grass\grass77\etc\python\grass\script\core.py",
line 1074, in gisenv
    s = read_command("g.gisenv", flags='n', env=env)
line 494, in read_command
    process = pipe_command(*args, **kwargs)
line 463, in pipe_command
    return start_command(*args, **kwargs)
line 393, in start_command
    return Popen(args, **popts)
line 54, in __init__
    cmd = shutil_which(args[0])
  File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in which
    if any(cmd.lower().endswith(ext.lower()) for ext in pathext):
  File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in <genexpr>
ERROR: Error in GUI startup. See messages above (if any) and if necessary,
please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package,
probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
     grass77 --help
See also: https://grass.osgeo.org/grass77/manuals/helptext.html
Exiting...
Drücken Sie eine beliebige Taste . . .
anyone any idea?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
Helmut Kudrnovsky wrote
C:\>grass77svn
in
<module>
line
35, in
<module>
77,
in
<module>
    Debug = DebugMsg()
39,
in __init__
    self.SetLevel()
45,
in SetLevel
<genexpr>
     grass77 --help
Exiting...
anyone any idea?
C:\>g.version -g
version=7.7.svn
date=2019
revision=r74428M
build_date=2019-04-26
build_platform=x86_64-w64-mingw32
build_off_t_size=8
best regards
Helmut
Same error on Vista with same version. Locale is set to Latvia.
Māris.
sestd., 2019. g. 27. apr., plkst. 14:58 — lietotājs Helmut Kudrnovsky
(<hellik@web.de>) rakstīja:
> Hi,
> C:\>grass77svn
> in
> <module>
> line
> 35, in
> <module>
> 77,
> in
> <module>
> Debug = DebugMsg()
> 39,
> in __init__
> self.SetLevel()
> 45,
> in SetLevel
> <genexpr>
> grass77 --help
> Exiting...
> anyone any idea?
C:\>g.version -g
version=7.7.svn
date=2019
revision=r74428M
build_off_t_size=8
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
