[GRASS-dev] OSX 10.11 Compiling (was: Re: New section in GRASS wiki for installation under Mac using homebrew)
Hello Rainer (and devs)
I think you only need to join the beta program (although I have the free developer account, just to be able to download xcode-related tools like the comand line tools).
I’ll summarise what I know so far about these issues:
  • When compiling, I get a lot of errors. These are related to creating html docs. As Glynn said, at this pint of compilation, the module is run with --html-description switch to get a list of its options. Any problems with wxpython will cause an error here.
  • Running make in the module directory show a call to libgrass_gis.7.0.1svn.dylib, but with the wrong path. It tries to load the library from the final package path (after installation), which doesn’t exists yet…
see the last lines of this output:
cd scripts/d.correlate/
GuanoAFBIOTA:d.correlate guano$ make
if [ “/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate” != “” ] ; then GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70 GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0 PATH=“/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH” PYTHONPATH=“/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH” DYLD_LIBRARY_PATH=“/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:” LC_ALL=C /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate --html-description < /dev/null | grep -v ‘|’ > d.correlate.tmp.html ; fi
dyld: Library not loaded: /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
Referenced from: /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
Reason: image not found
make: *** [d.correlate.tmp.html] Error 1
rm d.correlate.tmp.html
  • Ignoring the error and creating the package will work, and the package will install, although when run, the GUI will fail:
from grass.pygrass import messages
File “”, line 1, in
File “/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/init.py”, line 19, in
import grass.lib.gis as libgis
File “/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py”, line 23, in
_libs[“grass_gis.7.0.1RC2”] = load_library(“grass_gis.7.0.1RC2”)
File “/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py”, line 57, in load_library
raise ImportError,“%s not found.” % libname
ImportError: grass_gis.7.0.1RC2 not found.
cheers
Carlos
On Sun, Aug 2, 2015 at 7:51 AM, Rainer M Krug <r.m.krug@gmail.com> wrote:
Envoyé de mon iPhone
Le 31 juil. 2015 à 23:07, Carlos Grohmann <carlos.grohmann@gmail.com> a écrit :
Hi
The homebrew formula doesn’t really work on OSX 10.11 beta. In the log file (attached) I can see the same errors in compilation I got when tried to compile svn. They are related to html manual pages, but prevent installation from continue.
As I do not have 10.11 beta I can’t check it. But please let me (and osgeo4mac) know when you found a solution as I think it will also affect 6.4x and 7.0x versions.
Do I have to have a developer account with apple to have access to the beta?
Rainer
Carlos
brew tap rkrug/head-only
==> Tapping rkrug/head-only
Cloning into ‘/usr/local/Library/Taps/rkrug/homebrew-head-only’…
remote: Counting objects: 4, done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
Unpacking objects: 100% (4/4), done.
Checking connectivity… done.
Tapped 1 formula (27 files, 116K)
brew install grass-71
Error: rkrug/head-only/grass-71 is a head-only formula
Install with brew install --HEAD rkrug/head-only/grass-71
Warning: You are using OS X 10.11.
We do not provide support for this pre-release version.
You may encounter build failures or other breakage.
==> Installing grass-71 from rkrug/homebrew-head-only
Error: No available formula for nc_spm_08_grass7 (dependency of rkrug/head-only/grass-71)
guano$ brew install --HEAD rkrug/head-only/grass-71 --without-nc_spm_08_grass7
==> Cloning https://svn.osgeo.org/grass/grass/trunk
Updating /Library/Caches/Homebrew/grass-71–svn-HEAD
==> Patching
patching file include/Make/Install.make
Hunk #1 succeeded at 116 (offset 2 lines).
==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared --with-
==> make GDAL_DYNAMIC=
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Jul 31 17:36:12 BRT 2015
make: *** [default] Error 1
READ THIS: https://git.io/brew-troubleshooting
If reporting this issue please do so at (not Homebrew/homebrew):
https://github.com/rkrug/homebrew-head-only/issues
GuanoAFBIOTA:~ guano$
<02.make>
On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Very interesting!
From the brew recipe, it looks that one needs all dependencies installed via homebrew, is that right? I’m thinking that most will have Kyngsburie’s Frameworks already installed (at least GDAL). Same goes for wx-python.
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer@krugs.de> wrote:
Anna Petrášová <kratochanna@gmail.com> writes:
On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <Rainer@krugs.de> wrote:
Hi
I just added a section / new page in the WIKI for installation of GRASS
using homebrew. Please see
http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
and
http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
It would be great if some Mac / homebrew users would see if it works and
give me comments here.
I will try to test it next week. Thank you for your efforts!
Great - let me know how it goes, although I don’t know if I will be able
to reply as I am away and possibly only have very limited internet
access.
Rainer
Anna
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
grass-dev mailing list
grass-dev@lists.osgeo.org
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Carlos Grohmann <carlos.grohmann@gmail.com> writes:
comand line tools).
Thanks - I registered for the beta program an I am downloading El
Capitan at the moment.
Can you give any pointers how I can install it in Virtual Box as I do
not want to interfere with my production machine and do prefer the
flexibility of a virtual machine.
I'll take a look at the errors when I have it installed - which might be
in two weeks time as I will be on holiday next week.
Rainer
I'll summarise what I know so far about these issues:
- When compiling, I get a lot of errors. These are related to creating html
an error here.
- Running make in the module directory show a call to
package path (after installation), which doesn't exists yet..
if [
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
!= "" ] ; then
PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
  Referenced from:
- Ignoring the error and creating the package will work, and the package
  File "<stdin>", line 1, in <module>
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/__init__.py",
line 19, in <module>
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py",
line 23, in <module>
    _libs["grass_gis.7.0.1RC2"] = load_library("grass_gis.7.0.1RC2")
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py",
    raise ImportError,"%s not found." % libname
cheers
Carlos
écrit :
Hi
The homebrew formula doesn't really work on OSX 10.11 beta. In the log
As I do not have 10.11 beta I can't check it. But please let me (and
beta?
Rainer
Carlos
Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
Checking connectivity... done.
Install with `brew install --HEAD rkrug/head-only/grass-71`
Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
==> Patching
--with-
Very interesting!
via homebrew, is that right? I'm thinking that most will have Kyngsburie's
best
Carlos
wrote:
>> Hi
>> and
and
Great - let me know how it goes, although I don't know if I will be able
access.
Rainer
> Anna
>> Cheers,
>> Rainer
>> South Africa
>> Skype: RMkrug
>> PGP: 0x0F52F982
>> _______________________________________________
South Africa
Skype: RMkrug
PGP: 0x0F52F982
- Digital Terrain Analysis | GIS | Remote Sensing -
________________
________________
<02.make>
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Hi
I never installed OS X on a virtual machine, can’t help much there… (I’m using yosemite as primary machine and El Capitan on a secondary one)
While we are here, I tried the homebrew tap for 7.1svn on a Yosemite machine and it didn’t worked.
First I tried to install with libLas, add although it installed libels correctly, it can’t find the library when running GRASS’configure
:==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared --with-
checking for gdal-config… /usr/local/opt/gdal/bin/gdal-config
rm: conftest.dSYM: is a directory
checking whether to use libLAS… yes
checking for liblas-config… /usr/local/opt/liblas/bin/liblas-config
configure: error: *** Unable to locate libLAS library.
Then I tried with libels and it went OK, but when I run:
Serenity:~ guano$ /usr/local/bin/grass71
File “/usr/local/bin/grass71”, line 54, in
ENCODING = locale.getdefaultlocale()[1]
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py”, line 511, in getdefaultlocale
return _parse_localename(localename)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py”, line 443, in _parse_localename
raise ValueError, ‘unknown locale: %s’ % localename
ValueError: unknown locale: UTF-8
Serenity:~ guano$
any ideas?
thanks
Carlos
comand line tools).
I’ll take a look at the errors when I have it installed - which might be
Rainer
    an error here.
if [
!= “” ] ; then
LC_ALL=C
–html-description < /dev/null | grep -v ‘|’ >
Referenced from:
File “”, line 1, in
File
line 19, in
File
line 23, in
File
cheers
Carlos
écrit :
Hi
beta?
Rainer
Carlos
–without-nc_spm_08_grass7
==> Patching
–with-
Very interesting!
best
Carlos
wrote:
Hi
and
and
access.
Rainer
Anna
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
<02.make>
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Continuing…
Adding
export LC_ALL=en_US.UTF-8
export LANG=en_US.UTF-8
to my .bash_profile fixed the initial problem.
Then it can’t find wxpython, even though it installed it:
Serenity:~ guano$ brew install wxpython
Warning: wxpython-3.0.2.0 already installed
So, I had to add some stuff to my PYTHONPATH. The usual advised of including
/usr/local/lib/python2.7/site-packages
didn’t worked, I had to include /usr/local/lib/python2.7/site-packages/wx-3.0-osx_cocoa as well, since the wx.pth file is not read by python (see https://github.com/Homebrew/homebrew/issues/30844)
So I add:
export PYTHONPATH=brew --prefix/lib/python2.7/site-packages:brew --prefix/lib/python2.7/site-packages/wx-3.0-osx_cocoa
:$PYTHONPATH
And now it works!
(except for liblas. still need to figure out why it couldn’t find it at)
best
Carlos
On Wed, Aug 5, 2015 at 9:31 AM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Hi
Serenity:~ guano$
any ideas?
thanks
Carlos
comand line tools).
Rainer
    an error here.
if [
!= “” ] ; then
LC_ALL=C
Referenced from:
File “”, line 1, in
File
line 19, in
File
line 23, in
File
cheers
Carlos
écrit :
Hi
beta?
Rainer
Carlos
==> Patching
–with-
Very interesting!
best
Carlos
wrote:
Hi
and
and
access.
Rainer
Anna
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
<02.make>
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Hi
I never installed OS X on a virtual machine, can't help much there.. (I'm
OK - I will see how it goes. Maybe a second HDD is the easiest option.
machine and it didn't worked.
Could you give me the options you used for
| brew install --HEAD grass-71
so that I can check? because on Travis-ci the default installation is
installing without errors - I am trying it just now at
--8<---------------cut here---------------start------------->8---
https://travis-ci.org/rkrug/homebrew-experimental
--8<---------------cut here---------------end--------------->8---
correctly, it can't find the library when running GRASS'configure
--with-
checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
checking whether to use libLAS... yes
checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
  File "/usr/local/bin/grass71", line 54, in <module>
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py",
  File
    raise ValueError, 'unknown locale: %s' % localename
Serenity:~ guano$
I have everything (including python) in homebrew and I can install it,
although I have not tested any additional options.
I just added two more test cases / envelopes on travis-ci (--with-liblas
and --with-openblas) to test this and they are running at the moment ...
You can see them at
https://travis-ci.org/rkrug/homebrew-experimental/builds/74242734
And the --with-liblas fails there as well. OK.
I added the -v for the v=compile to get a better picture ...
https://travis-ci.org/rkrug/homebrew-experimental/builds/74248159
same errors.
I found the following:
grass70 not detecting latest source build of libLAS (1.7.0)
https://trac.osgeo.org/grass/ticket/2065
And the only reference I see is that liblas newer than 1.7 is
installed, but homebrew installs 1.8 - so this is not the problem.
OK - I think I narrowed it down: it seems that the problem is gdal.
I will open another subject with this.
Rainer
any ideas?
thanks
Carlos
the
> comand line tools).
Rainer
html
cause
> an error here.
> if [
> != "" ] ; then
> LC_ALL=C
> Referenced from:
> File
> File
> File
> cheers
> Carlos
>> écrit :
>> Hi
tried
>> beta?
>> Cheers
>> Rainer
>> Carlos
>> ==> Patching
>> --with-
will
>>> Very interesting!
installed
Kyngsburie's
>>> best
>>> Carlos
>>>> wrote:
>>>> >> Hi
>>>> GRASS
>>>> >> and
works
>>>> and
able
>>>> access.
>>>> Thanks,
>>>> Rainer
>>>> > Anna
>>>> >> Cheers,
>>>> >> Rainer
>>>> >> South Africa
>>>> >> Skype: RMkrug
>>>> >> PGP: 0x0F52F982
>>>> South Africa
>>>> Skype: RMkrug
>>>> PGP: 0x0F52F982
>>> ________________
>> ________________
>> <02.make>
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
OK - I tried the installation of grass 70 from osgeo4mac and it has the
same error. I have reported it on their website (see
https://github.com/OSGeo/homebrew-osgeo4mac/issues/102)
So it is not a 7.1 issue.
Rainer
Rainer M Krug <Rainer@krugs.de> writes:
Hi
--with-
  File
  File
Serenity:~ guano$
You can see them at
same errors.
Rainer
any ideas?
thanks
Carlos
the
> comand line tools).
Rainer
html
cause
> an error here.
> if [
> != "" ] ; then
> LC_ALL=C
> Referenced from:
> File
> File
> File
> cheers
> Carlos
>> écrit :
>> Hi
tried
>> beta?
>> Cheers
>> Rainer
>> Carlos
>> ==> Patching
>> --with-
will
>>> Very interesting!
installed
Kyngsburie's
>>> best
>>> Carlos
>>>> wrote:
>>>> >> Hi
>>>> GRASS
>>>> >> and
works
>>>> and
able
>>>> access.
>>>> Thanks,
>>>> Rainer
>>>> > Anna
>>>> >> Cheers,
>>>> >> Rainer
>>>> >> South Africa
>>>> >> Skype: RMkrug
>>>> >> PGP: 0x0F52F982
>>>> South Africa
>>>> Skype: RMkrug
>>>> PGP: 0x0F52F982
>>> ________________
>> ________________
>> <02.make>
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Thanks to Glenn, this should be working now:
brew install -build-from-source liblas
brew install --with-liblas HEAD grass-71
I also updated the wiki at
http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew#How_to_install_GRASS_GIS_7.1_SVN_Head
Rainer
Rainer
Hi
--with-
  File
  File
Serenity:~ guano$
You can see them at
same errors.
Rainer
any ideas?
thanks
Carlos
the
> comand line tools).
Rainer
html
cause
> an error here.
> if [
> != "" ] ; then
> LC_ALL=C
> Referenced from:
> File
> File
> File
> cheers
> Carlos
>> écrit :
>> Hi
tried
>> beta?
>> Cheers
>> Rainer
>> Carlos
>> ==> Patching
>> --with-
will
>>> Very interesting!
installed
Kyngsburie's
>>> best
>>> Carlos
>>>> wrote:
>>>> >> Hi
>>>> GRASS
>>>> >> and
works
>>>> and
able
>>>> access.
>>>> Thanks,
>>>> Rainer
>>>> > Anna
>>>> >> Cheers,
>>>> >> Rainer
>>>> >> South Africa
>>>> >> Skype: RMkrug
>>>> >> PGP: 0x0F52F982
>>>> South Africa
>>>> Skype: RMkrug
>>>> PGP: 0x0F52F982
>>> ________________
>> ________________
>> <02.make>
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Yes,
worked fine now.
thanks
Carlos
–8<---------------cut here---------------start------------->8—
–8<---------------cut here---------------end--------------->8—
Rainer
Rainer
Hi
–with-
File
File
Serenity:~ guano$
I just added two more test cases / envelopes on travis-ci (–with-liblas
and --with-openblas) to test this and they are running at the moment …
You can see them at
I added the -v for the v=compile to get a better picture …
same errors.
Rainer
any ideas?
thanks
Carlos
the
comand line tools).
Rainer
    html
    cause
    an error here.
if [
!= “” ] ; then
LC_ALL=C
Referenced from:
File “”, line 1, in
File
line 19, in
File
line 23, in
File
cheers
Carlos
écrit :
Hi
tried
beta?
Rainer
Carlos
==> Patching
–with-
will
Very interesting!
installed
Kyngsburie’s
best
Carlos
wrote:
Hi
and
works
and
able
access.
Rainer
Anna
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
<02.make>
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Yes,
worked fine now.
Great
Rainer
thanks
Carlos
Rainer
> Cheers,
> Rainer
>>> Hi
(I'm
--enable-shared
>>> --with-
>>> File
>>> File
>>> Serenity:~ guano$
>> You can see them at
>> same errors.
>> Cheers,
>> Rainer
>>> any ideas?
>>> thanks
>>> Carlos
free
like
>>>> the
>>>> > comand line tools).
be
>>>> Thanks,
>>>> Rainer
creating
>>>> html
>>>> cause
>>>> > an error here.
>>>> > if [
>>>> > != "" ] ; then
>>>> > LC_ALL=C
>>>> > Referenced from:
package
>>>> > File
>>>> > File
>>>> > File
>>>> > cheers
>>>> > Carlos
>>>> >> écrit :
>>>> >> Hi
log
>>>> tried
(and
affect
the
>>>> >> beta?
>>>> >> Cheers
>>>> >> Rainer
>>>> >> Carlos
>>>> >> ==> Patching
--enable-shared
>>>> >> --with-
you
>>>> will
>>>> >>> Very interesting!
>>>> installed
>>>> Kyngsburie's
wx-python.
>>>> >>> best
>>>> >>> Carlos
Rainer@krugs.de>
>>>> >>>> wrote:
>>>> >>>> >> Hi
installation of
>>>> >>>> GRASS
>>>> >>>> >> and
>>>> works
>>>> >>>> and
be
>>>> able
internet
>>>> >>>> access.
>>>> >>>> Thanks,
>>>> >>>> Rainer
>>>> >>>> > Anna
>>>> >>>> >> Cheers,
>>>> >>>> >> Rainer
(Conservation
>>>> >>>> >> South Africa
>>>> >>>> >> Skype: RMkrug
>>>> >>>> >> PGP: 0x0F52F982
(Conservation
>>>> >>>> South Africa
>>>> >>>> Skype: RMkrug
>>>> >>>> PGP: 0x0F52F982
>>>> >>> ________________
>>>> >> ________________
>>>> >> <02.make>
>>>> South Africa
>>>> Skype: RMkrug
>>>> PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
