[GRASS-dev] OSX Snow Leopard problem with python
I had some problems getting wxpython GUI to run after upgrading to OSX 10.6 Snow Leopard. I thought I might need to rebuild (I was using the Leopard binaries), but that doesn't help.
When I got GRASS to execute to correct Python (another issue I know how to workaround), starting the GUI does nothing. With DEBUG level 5, I get:
GRASS 6.5.svn (spearfish60):~ > g.gui wxpython
D1/5: Attempting to start 'wxpython' GUI ...
D3/5: forking 'python' ...
re-executing using pythonw
And the GUI never appears. I kinda wonder if it has something to do with the old fork/exec problem that started with Leopard (or was is Tiger), and maybe now instead of a warning, it simply fails (nothing else in the console log).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
William,
I have one student in class who has your binaries running on Snow Leopard, including wxpython GUI (I believe)
  I can check with him in case you still have problems,
Helena
- Ford Prefect
grass-dev mailing list
grass-dev@lists.osgeo.org
Huh? At least one other person has contacted me with the same problem. I would be nice if you could verify that your student is running the wxgui. Are they using the python.org Python, or the system python?
On Sep 6, 2009, at 7:53 PM, Helena Mitasova wrote:
William,
Helena
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
After some tinkering, I found that the utils.reexec_with_pythonw() is not working. I was able to manually run the GUI by commenting the utils.reexec_with_pythonw() lines in wxgui.py and menuform.py and starting the gui with
pythonw "$GISBASE/etc/wxpython/wxgui.py"
- Ford Prefect
- Tarzan, on war
On Mon, Sep 7, 2009 at 1:28 AM, William
Same problem here on Mandriva: due to a change some days ago the wxGUI is
gone - I only get the old map and then it silently disappears.
BTW:
checking for MacOSX App... no
checking for MacOSX architectures...
checking for MacOSX SDK... checking for /SDKSettings.plist... no
configure: error: *** specified SDK does not exist or is not a SDK
I can even no longer configure GRASS :frowning: The SDK test needs apparently
to be conditionalized: if on Linux/nonMac please don't test MacOSX SDK.
I have tried here on Mandriva 64bit
GRASS 6.5.svn (patUTM32):~/grass65 > g.gisenv set=DEBUG=5
GRASS 6.5.svn (patUTM32):~/grass65 > g.gui wxpython
Same thing - old map appears, disappears and that's it.
On Mon, Sep 7, 2009 at 5:37 AM, William
the gui with
I see it only in wxgui.py:
Index: wxgui.py
--- wxgui.py (revision 39055)
+++ wxgui.py (working copy)
@@ -1608,7 +1608,7 @@
     # reexec for MacOS
- utils.reexec_with_pythonw()
+ #utils.reexec_with_pythonw()
     # process command-line arguments
Unfortunately it does not help.
I see http://trac.osgeo.org/grass/ticket/594
which seems to be related.
Perhaps some more magic is needed (bad URL with spaces)?
http://wiki.wxpython.org/Automatically Calling pythonw on Mac OS X
On Sep 7, 2009, at 2:25 AM, Markus Neteler wrote:
BTW:
Actually, the test doesn't depend on the OSX app build, it applies to a Unix OSX build also. I made the tests check for empty instead of 'no' (I thought the autoconfig magic would fill in no for empty options). Sorry for the mixup.
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
I don't even get anything that appears, just quiet.
the gui with
Index: wxgui.py
    # reexec for MacOS
menuform.py is in gui_modules subfolder. I didn't see that one at first also, and the GUI didn't start until I fixed both of them.
(hehe, and Mail's automatic URL recognition stopped at 'Automaticaly')
No spaces, or other odd chars, in the path to pythonw or GRASS.
I wonder if there is just something wrong with that reexec function definition, since you have a similar problem on Linux (where it never attempts the exec).
A couple other oddities I noticed:
- menuform.py has a shebang (and hardwired to /usr/bin/python), but it's only ever imported
- the reexec in menuform.py is redundant
But fixing these didn't help...
And, a potential problem: the reexec doesn't respect the GRASS_PYTHON setting. g.gui starts using GRASS_PYTHON, but the reexec is simply 'pythonw', which may not be from the same python build. I could even set GRASS_PYTHON to a specific pythonw, but it will still reexec with 'pythonw'.
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
Hi
When I try update r.stream.basins directory for most of files I receive message:
it is
svn: Item '/grass-addons/raster/r.stream.basins/global.h' is out of date
svn: Zatwierdzenie nie powiodło się (szczegóły poniżej): // this means: commit failed (details below)
svn: File or directory 'global.h' out of date. try updating
svn: resource out of date; try updating
what could be the reason for?
greetings
Jarek
it is
is out of date
updating
someone else made modifications to those files since you last committed.
  https://trac.osgeo.org/grass/log/grass-addons/raster/r.stream.basins
always run "svn up" before you start up again after a break.
  https://trac.osgeo.org/grass/wiki/HowToSVN#Beforemakingchanges
Hamish
ps- also, please use informative commit comments whenever you check
something in, they help a lot with review & maintenance.
Hamish pisze:
it is
is out of date
updating
Hamish
thanks I did.
Jarek
