[GRASS-dev] Overflow warning in r.mapcalc calculation
I am having trouble with the following computation, which gives me an overflow warning (“WARNING: Overflow occured in the calculation”).
r.mapcalc "A = if(B==0, (round(C/0.0001)-1175699902)/(3007966667-1175699902) *100.0, 1)" --overwrite
whereby C is a map with values between 1 and 31000. It seems to be related to the size of the numbers (no warning if I divide C by 0.001), but I am not clear what limit I am hitting here or how to avoid this.
The warning does not stop the calculation, and the resulting map seems to be correct. However, I rather avoid this warning, also because the warning message causes problems when running in batch from within R.
I am running GRASS 7.0 on Ubuntu 13.04 64 bit.
Best
Paulo
Paulo van Breugel <p.vanbreugel@gmail.com> writes:
I am having trouble with the following computation, which gives me an overflow warning ("WARNING: Overflow occured in the
calculation").
oerflow usually means that the result of a calculation does not fit into
the variable type selected, i.e. is either smaller then the smallest
value which can be stored or larger then the largest value.
GRASS uses FCELL (float) and DCELL (double) varisbles, where double can
store a larger range (sorry - I don't have the actual values at hand).
You should be able to do the calculations by explicitely converting the
result to double by using the double() function:
UNTESTED:
  r.mapcalc "A = if(B==0, double( (round(C/0.0001)-1175699902)/(3007966667-1175699902) *100.0 ), 1) " --overwrite
should work, although untested.It is possible, thet the conversion to
double needs to be made inside the calculation, depending where the
actual overflow occurs.
Yes - overflow is a warning only, but *usually* results in wrong
results! I fell in that trap once and it took me some time to figure out
what was going on, as, if I remember correctly, no warning was issued
(GRASS 6.4?).
Rainer
Best
Paulo
grass-dev mailing list
grass-dev@lists.osgeo.org
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
Hi Rainer,
Thanks a lot for your reply. The problem is indeed that the result of the calculation does not fit into the variable and your answer made me realize I had to take a closer look at what happens inside the formula. As it turns out, the problem lies in the following part of the formula:
round(C/0.0001)
The output of round() is an integer and c/0.0001 gives values that are larger then the maximum number for integer layers (which I presume is (2^31)-1). So I need to rethink the formula and the use of round.
Paulo
On 05/15/2013 03:51 PM, Rainer M. Krug wrote:
Paulo van Breugel [<p.vanbreugel@gmail.com>](mailto:p.vanbreugel@gmail.com) writes:
calculation").
UNTESTED:
(GRASS 6.4?).
Rainer
Best
Paulo
[grass-dev@lists.osgeo.org](mailto:grass-dev@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-dev](http://lists.osgeo.org/mailman/listinfo/grass-dev)
Paulo van Breugel
Department of Geosciences and Natural Resource Management
Section of Forest, Nature and Biomass
University of Copenhagen
Rolighedsvej 23
1958 Frederiksberg C
Phone: +45 353-31646
Phone: +31 6 12189147
e-mail: [pvb@life.ku.dk](mailto:pvb@life.ku.dk)
e-mail: [p.vanbreugel@gmail.com](mailto:p.vanbreugel@gmail.com)
overflow warning ("WARNING: Overflow occured in the calculation").
The round() function always returns an integer, regardless of its
argument types. Integers are always 32-bit, so the result is limited
to the range +/- 2147483647 (2^31-1).
r.mapcalc “A = if(B==0, (round(C/0.0001)-1175699902)/(3007966667-1175699902) *100.0, 1)” --overwrite
True - but is there an equivalent function to round numbers outside the integer range? Would be useful. Looking at the functions in r.mapcalc, I can’t think of a way of doing this?
Rainer
Glynn Clements glynn@gclements.plus.com
South Africa
Fax (F): +33 - (0)9 58 10 27 44
Skype: RMkrug
I would second that, it certainly would be handy to be able to round numbers outside the integer range and in addition, rounding with a specific number of decimal places, like e.g., the function round() in R. Is there a specific reason the round() function results in an integer?
Paulo
Rainer
South Africa
Skype: RMkrug
I just looked at the round function in xround.c, and it does not look to
complicated to modify round() to obtain have three more functions, aligned to the
R functions:
From the R help:
| ‘ceiling’ takes a single numeric argument ‘x’ and returns a
| numeric vector containing the smallest integers not less than the
| corresponding elements of ‘x’.
| ‘floor’ takes a single numeric argument ‘x’ and returns a numeric
| vector containing the largest integers not greater than the
| ‘trunc’ takes a single numeric argument ‘x’ and returns a numeric
| vector containing the integers formed by truncating the values in
| ‘x’ toward ‘0’.
In addition, an additional argument could be added to the round()
function to round to the number of specified decimal places, so that it
is equivalent to your suggestion, Paulo.
From the R help:
| ‘round’ rounds the values in its first argument to the specified
| number of decimal places (default 0).
Unfortunately I don't have the experience in C and absolutely no time at
the moment to get into it.
Rainer
Paulo
can't think of a way of doing this?
Rainer
South Africa
Skype: RMkrug
South Africa
Skype: RMkrug
Thanks for that Rainer. I have no expertise in C too, but let me file a feature / enhancement request, perhaps somebody can pick this up.
Paulo
R functions:
>From the R help:
|      ‘x’ toward ‘0’.
>From the R help:
Rainer
Paulo
On Wed, May 15, 2013 at 9:20 PM, Rainer M Krug [<r.m.krug@gmail.com>](mailto:r.m.krug@gmail.com) wrote:
Rainer
Glynn Clements [<glynn@gclements.plus.com>](mailto:glynn@gclements.plus.com)
South Africa
email:      [Rainer@krugs.de](mailto:Rainer@krugs.de)
Skype:      RMkrug
Paulo van Breugel
Rolighedsvej 23
integer range?
No.
Would be useful. Looking at the functions in r.mapcalc, I can't
outmap = eval(d = inmap % 1.0, dd = if(d < 0,d+1,d), inmap - dd + if(dd > 0.5,1,0))
The added complexity is because the % operator returns a negative
value for a negative numerator. Specifically, a % b = a - int(a/b)*b,
where conversion to an integer rounds toward zero.
It's not clear whether this behaviour is intentional or just how it
turned out. This is how C's % operator is defined for integer
arguments (for floating-point values, the fmod() library function
behaves similarly).
Also: r.mapcalc's % operator will fail if a/b overflows the range of
an integer. That should be fixed
R functions:
One option is to modify round() to take a second argument (defaulting
to 1), and have it return the first argument rounded to the nearest
multiple of the second. The return type would be that of the second
argument, i.e. round(x,1) rounds to the nearest integer and returns an
integer, round(x,1.0) rounds to the nearest integer and returns a
float, round(x,1e-3) would round to 3 decimal places (i.e. the nearest
multiple of 0.001), etc.
Glynn Clements <glynn@gclements.plus.com> writes:
integer range?
No.
behaves similarly).
R functions:
Sounds like a sensible approach without adding to many new
functions. But I would actually split the two, i.e. have two more
arguments, where one specifies the type,
and the other one the number of decimals to round to, i.e.
round(x, 0, "I") would be the default, rounding to whole number and
return an integer
round(x, 0, "F") would round to the next whole number but return an
float and
round(x, 0, "D") would round to the next whole number ad return a
double.
round(x, 2, "I") would return an error, while
round(x, 2, "D") would return a double, rounded to two decimals.
Rainer
South Africa
Skype: RMkrug
return an integer
That interface isn't possible. r.mapcalc doesn't have a string type,
and there's no way that a function's return type can depend upon the
value of a parameter.
Hi Glynn and Rainer
Happy to see this exchange of ideas. It would be great if this could be implemented. Do you think it is useful I make a feature request on the bug tracker (with link to this email thread) so the idea doesn’t get lost?
On Fri, May 17, 2013 at 4:38 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
round(x, 0, “I”) would be the default, rounding to whole number and
return an integer
That interface isn’t possible. r.mapcalc doesn’t have a string type,
and there’s no way that a function’s return type can depend upon the
return an integer
In this case I would suggest different functions, e.g.
round(x) - as it is now
roundI(x, dec) - round to integer, dec>0 is ignored, dec<0 as below
roundD(x, dec) - round to double, where dec is the number of decimals it
should be rounded to
roundF(x, dec) - round to float, where dec is the number of decimals it
if dec is positive, it is the number of decimals, if negative the
... (no idea what it is called, but if it is -1, 111 is rounded to 110,
-2 111 is rounded to 100)
default from dec would be 0.
These different functions would also have the advantage of probably
being faster then one single function.
Rainer
South Africa
Skype: RMkrug
Hi Glynn and Rainer
tracker (with link to this email thread) so the idea doesn't get lost?
Yes please - I think that would be useful.
Rainer
On Fri, May 17, 2013 at 4:38 PM, Glynn Clements <glynn@gclements.plus.com>wrote:
> return an integer
<#secure method=pgpmime mode=sign>
South Africa
Skype: RMkrug
On Fri, May 17, 2013 at 5:13 PM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Hi Glynn and Rainer
Instead of
--overwrite
try
(round(C/0.0001)-1175699902.0)/(3007966667.0-1175699902.0) *100.0, 1)"
--overwrite
or better with whitespaces
r.mapcalc "A = if(B == 0, (round(C / 0.0001) - 1175699902.0) /
(3007966667.0 - 1175699902.0) * 100.0, 1)" --overwrite
adding .0 to numbers forces all calculations to be done with floating
point double precision
Markus M
> return an integer
Thanks Markus,
That is certainly a good suggestion. The problem however remains I think with the part
round(C / 0.0001)
If C/0.0001 > 2^31, i.e., larger then the maximum possible integer, there will be an error.
The white spaces, is that for another reason then being clearer?
Paulo
[<p.vanbreugel@gmail.com>](mailto:p.vanbreugel@gmail.com) wrote:
Hi Glynn and Rainer
Instead of
--overwrite
try
--overwrite
Markus M
On Fri, May 17, 2013 at 4:38 PM, Glynn Clements [<glynn@gclements.plus.com>](mailto:glynn@gclements.plus.com)
return an integer
Paulo van Breugel
Rolighedsvej 23
Instead of
--overwrite
try
--overwrite
That won't help; the problem is that round() returns an integer.
It wouldn't be particularly hard to change it so that the return type
is the same as the argument type, but that might break existing
scripts.
>> return an integer
1. I wouldn't bother with separate functions, but instead use the type
of the second argument to determine the return type, i.e.
  round(x, 1) -> CELL
  round(x, 1.0f) -> FCELL
  round(x, 1.0) -> DCELL
The value of the second argument can be ignored, or it can be used for
other purposes.
2. Rounding to a given number of decimals is unnecessarily limiting.
The algorithm for generalised rounding is essentially:
  roundTo(x, k) = round(x / k) * k.
Rounding to N decimal places is just a case of using k=1/10^N. If you
allow k to be specified directly, then you can round to arbitrary
steps (e.g. k=5 would round to the nearest multiple of 5, etc).
3. However: there's a slight problem with doing it that way: 0.1 isn't
exactly representable in binary, so e.g. x/0.1 isn't equal to x*10; it
would be more accurate to use:
  roundTo(x, k) = round(x * k) / k
where k is the reciprocal of the step, so k=10^N to round to N decimal
places (or k=2 to round to 1/2).
The downside is that the interface is less useful if you want to round
to something other than a fixed number of decimal places. E.g. if you
wanted to round to the nearest multiple of 45 degrees, you'd need to
use k=1.0/45, which isn't exactly representable.
Hi Glynn,
In case you haven’t seen it, Markus Metz has implemented in trunk r56313 the option to have the same raster type as output of round() as the input type, see ticket 1976 (http://trac.osgeo.org/grass/ticket/).
I sure hope it does not brake existing scripts, as this is a very useful enhancement I think.
In case you haven't seen it, Markus Metz has implemented in trunk r56313
<http://trac.osgeo.org/grass/changeset/56313&gt; the option to have the
I've seen it. Don't rely upon that behaviour, as I intend to change
it: http://trac.osgeo.org/grass/ticket/1976#comment:4
