I'm having trouble getting the 'Overlay grids and lines' tool in gis.m to
draw a grid. No matter what the grid spacing is set to, or whether I choose
to draw a geographic grid or not, no grid draws.
Running the command from the CLI also falis to draw a grid:
# Geographic grid
d.grid -g size=00:00:01 origin=0,0 color=170:170:170 bordercolor=0:0:0
Segmentation fault
# UTM grid
d.grid size=2000 origin=0,0 color=170:170:170 bordercolor=0:0:0
Segmentation fault
Can anyone verify this problem? It's been persistent for weeks, despite
daliy cvs updates.
~ Eric.
Patton, Eric wrote:
# Geographic grid
Segmentation fault
# UTM grid
Segmentation fault
daliy cvs updates.
d.grid segfaults for me too if I use RGB triplets for color or
bordercolor. If I use names (blue, red etc.) it works.
Maciek
# Geographic grid
d.grid -g size=00:00:01 origin=0,0 color=170:170:170 bordercolor=0:0:0 Segmentation fault
# UTM grid
Segmentation fault
daliy cvs updates.
I can confirm the problem.
Moritz
Maciej Sieczka wrote:
Patton, Eric wrote:
# Geographic grid
# UTM grid
Segmentation fault
daliy cvs updates.
Actually it works as long as the RGB values are 0 or 255. As soon as
they are something else it segfaults.
Moritz
Hmm, for me it segfaults whatever the values, eg.:
$ d.grid size=2000 origin=0,0 bordercolor=1:1:1
Segmentation fault
Maciek
Segmentation fault
d.grid calls D_parse_color() before calling R_open_driver(), which
won't work unless the colour is one of the predefined colours
(D_parse_color() allocates the specified colour within the driver then
returns the index of the allocated colour).
