I wonder if the r.li.daemon code could be moved up to (some) library level
to
use parallelization whereever possible. Since the code is there and seems to
work...
View this message in context: http://www.nabble.com/Parallelized-raster-computing%3A-using-r.li.daemon-code--tf4205362.html#a11962114
Sent from the Grass - Dev mailing list archive at Nabble.com.
