[GRASS-dev] "Parameter <layer>, require: string" in v.db.dropcolumn
Hi all!
Using "v.db.dropcolumn" within from latest "grass_trunk",
I wonder why the "layer" parameter in "v.db.dropcolumn" is required to be a
string as stated in an error message while trying to run a py-grass script:
File "/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/python/grass/pygrass/modules/__init__.py", line 466, in __call__
    self.inputs[key].value = val
gnu/etc/python/grass/pygrass/modules/__init__.py", line 182, in _set_value
    raise TypeError(str_err % (self.name, self.typedesc, type(value)))
TypeError: The Parameter <layer>, require: string, get: <type 'int'> instead
Shouldn't the "layer" parameter be simply an integer?
Thanks, Nikos
On 19/11/12 11:42, Nikos Alexandris wrote:
Hi all!
TypeError: The Parameter<layer>, require: string, get:<type 'int'> instead
In GRASS7 you can name layers, which is used particularly for the direct OGR access. As the man page for v.db.dropcolumn says:
"layer=string [required]
     Layer number or name
     A single vector map can be connected to multiple database tables.
     This number determines which table to use. When used with direct
     OGR access this is the layer name."
Moritz
2012/11/21 Moritz Lennert <mlennert@club.worldonline.be>:
also GRASS vector layers is possible to access by names. By it's not
really used and probably also not fully supported. Most of modules are
probablty casting layer to integer. See [1].
Martin
[1] http://grass.osgeo.org/programming7/field_8c.html#acdcddf923a4eb58aafdba8198fe280cd
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
