Hi Nikos,
If you are interested in dictionary output you could do:
category_labels = grass.parse_command('r.category', map='youmap', delimiter='\t')
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces@lists.osgeo.org> On Behalf Of Nikos Alexandris
Sent: tirsdag 21. august 2018 02:02
To: Moritz Lennert <mlennert@club.worldonline.be>
Cc: GRASS-GIS development mailing list <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] Parsing output of r.category which includes labels
* Moritz Lennert <mlennert@club.worldonline.be> [2018-08-20 13:40:36 +0200]:
On 19/08/18 22:19, Nikos Alexandris wrote:
If I am not wrong, all use cases of `read_command()` [0, 1], in (at
least) the grass-addons repository, do not consider an output from
`r.category` which includes labels.
[0]
https://grass.osgeo.org/grass74/manuals/libpython/script.html?highligh
t=read_command#script.core.read_command
[1]
https://grass.osgeo.org/grass75/manuals/libpython/script.html?highligh
I work on such a case where category numbers come along with label strings.
To read category numbers, I came up with:
import grass.script as grass
grass.read_command('r.category', map=base).split('\n')[:-1]
for category in categories:
category = category.split('\t')[0] ```
Is there any other command that will do this better? Would you
consider adding one?
If all the modules are trying to do is get a list of category values,
your approach seems the right one to me, but a simple list
comprehension should do the trick in one line:
cats = [int(x[0]) for x in [x.split('\t') for x in
g.read_command('r.category', map='RasterMap').splitlines()]]
Great. I love comprehensions (and generators).
It's one of my favourite Python exercises.
This will work whether there are labels or not. IMHO, there is no need
to use anything more sophisticated.
Especially since a
grep -R "r.category" * | grep read_command
only gives 4 hits:
imagery/i.segment.uspo/i.segment.uspo.py: numsegments =
len(gscript.read_command('r.category',
raster/r.geomorphon/testsuite/test_r_geom.py: category =
read_command('r.category', map=self.outele)
read_command('r.category', map=self.outsint)
raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py: numneighbors =
The first and last only read the length (number) of categories, so this
isn't an issue.
Have you met other instances ?
No. Yet, my Skepsis now is the following:
The argument you present, if I understand it right, is "no need to bother", since there aren't but a few potential use cases.
What about better integration and more joyful scripting? `r.category` handles both values and labels. And there is currently no `grass.script` helper function that considers both labels out of the box.
For example, a parser helper that will return a dictionary.
Is this "too much" here?
Thanks Moritz,
Nikos
