[GRASS-dev] Passed: GRASS-GIS/grass-ci#1472 (master - 7d9feb7)
Build #1472 passed.
28 minutes and 45 seconds
Martin Landa
7d9feb7 Changeset →
If GRASS_RANDOM_SEED is set, use it to seed the random generator when
G_srand48_auto is called. This helps makeing the build reproducible
(html/random.png)
Based on 04-srand48_auto-from-SOURCE_DATE_EPOCH.patch, see #3042
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69217 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
We are seeing build failures due to new sudo-enabled Precise and Trusty images. See more details here. Thank you for your enduring patience.
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
