[GRASS-dev] Passing several floating values to one single option
This might be very simple, but I can't find an answer in the doco - so
here I am,
I'm trying to pass several floats to a single option in a Python script:
python my.module.py input=input output=output myoption=0.1,0.2,0.5
Is there a clever way to declare myoption so that it would parse it as
some 3 floats? Or do I need to define it as a string and parse it
manually?
Pierre
Scientist
Landcare Research, New Zealand
On Thu, Sep 13, 2012 at 2:07 AM, Pierre Roudier
<pierre.roudier@gmail.com> wrote:
here I am,
some 3 floats?
Add
#% multiple : yes
to the option definition section of myoption.
Markus M
here I am,
manually?
The values in the "options" dictionary returned from the parser()
function are always strings. You can parse the string with:
  myoption = map(float, options['myoption'].split(','))
The option definition in the script should have:
  #% type: double
  #% multiple: yes
This allows g.parser to validate the option syntax, so you can rely
upon the string being in the correct format. If the values have a
fixed range, you can use e.g.:
  #% options: 0.0-1.0
to have the parser check that the values fall within the range.
  #% type: double
  #% multiple: yes
  #% options: 0.0-1.0
For more information on option definitions, see:
http://grass.osgeo.org/programming7/gislib.html#Complete_Structure_Members_Table
On Thu, Sep 13, 2012 at 12:44 PM, Glynn Clements
Added to
http://grass.osgeo.org/wiki/GRASS_Python_Scripting_Library#Parsing_the_options_and_flags
Thanks all for the trick,
Added to
Perfect place for it I reckon,
Pierre
Scientist
