[GRASS-dev] patch - allows g.mapset to create mapsets
As per the discussion with Hamish from last week, I've created a patch
to g.mapset that allows mapsets to be created if they don't exist.
User has to specify the flag '-c' to enable this behaviour.
I implemented this behaviour by creating a G_make_mapset function in
the gis library.
Attached is a tar.gz containing the patch for files include/gisdefs.h
and general/g.mapset/main.c (gmapset.diff) and and a new file with the
new function (lib/gis/make_mapset.c)
Hopefully someone has time to review and add this to CVS.
-Joel
"Wish not to seem, but to be, the best."
                -- Aeschylus
Attached file this time.
On 10/23/06, Joel Pitt <joel.pitt@gmail.com> wrote:
the gis library.
-Joel
                -- Aeschylus
-Joel
                -- Aeschylus
(attachments)
gmapsetcreate.tar.gz (2.44 KB)
Joel Pitt wrote:
the gis library.
    /* Make the mapset. */
    sprintf( path, "%s/%s/%s", gisdbase_name, location_name, mapset_name );
    if( mkdir( path, 0775 ) != 0 )
        return -1;
The mkdir() call should use mode 0777; the user's umask setting will
affect the actual permissions.
In general, directories should use 0777, files should use either 0777
(if they are executable) or 0666 (if they are not). The user can
always remove permissions through their umask setting, but can't add
permissions (other than manually running chmod).
    /* Copy default window/regions to new mapset */
    G__put_window( &default_window, "", "DEFAULT_WIND" );
    G__put_window( &default_window, "", "WIND" );
Normal mapsets don't have a DEFAULT_WIND file; only the PERMANENT
mapset has that. IOW, DEFAULT_WIND is a property of a location rather
than a mapset.
        return -1;
than a mapset.
Updated with permissions 0777 and removed the call to add DEFAULT_WIND
to the new mapset.
-Joel
                -- Aeschylus
(attachments)
gmapsetcreate.tar.gz (3.35 KB)
> return -1;
> than a mapset.
to the new mapset.
The attachment contains the wrong file: make_loc.c rather than
make_mapset.c.
Sorry, have attached tar with correct file, make_mapset instead.
> > return -1;
> > than a mapset.
> to the new mapset.
make_mapset.c.
-Joel
                -- Aeschylus
(attachments)
gmapsetcreate.tar.gz (2.41 KB)
Committed to CVS.
I am unable to compile lib/init/mke_loc.c, to use mkdir function I
have to add sys/stat.h header to mke_loc.c (on Debian GNU/Linux
unstable).
Best regards, Martin
2006/10/27, Glynn Clements <glynn@gclements.plus.com>:
Committed to CVS.
grass-dev mailing list
grass-dev@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
unstable).
Fixed in CVS.
BTW, this problem isn't related to Joel's patch which is being
discussed in this thread, but to my patch in the thread:
Re: [bug #5218] (grass) wingrass: creating new location from startup screen with projection values fails
etc/set_data (from lib/init) has its own code for creating the
location/mapset directories; it doesn't use the libgis functions.
