[GRASS-dev] PATCH: debugging.txt
Any suggestions/objections to the attached patch?
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
(attachments)
debug.diff (1.9 KB)
+ * After running 'configure', include/Make/Platform.make should be
+ edited and append -pg to LINK_FLAGS
No need; just add -pg to LDFLAGS when running configure, e.g.
  CFLAGS='-pg -O2' LDFLAGS=-pg ./configure ...
Ah! Thank you. That makes things a bit easier to document. Changes
attached.
(attachments)
debug.diff (1.92 KB)
