Unfortunately if QGIS is compiled without stdin/stdout and then run
from batch, cmd.exe or MSYS shell, it will open command window for a
while always when a new GRASS database driver is started.
To GRASS 6.3-CVS.
As far as I understand, QGIS uses GRASS from CVS to prepare the
winGRASS extension. 6.2.1 is completely lagging behind concerning
Windows fixes.
I think that it is fine like that.
On Sun, Dec 17, 2006 at 06:50:40PM +0100, Paolo Cavallini wrote:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
to which branch?
it would be good to have in 6.2.1(.1?), so coming qgis will have it by
default?
pc
Markus Neteler ha scritto:
> On Sun, Dec 17, 2006 at 05:53:25PM +0100, Radim Blazek wrote:
>> Here is the patch for https://svn.qgis.org/trac/ticket/448
>> (grass/lib/db/dbmi_client/start.c).
>> Radim
> Patch applied.
> Markus
> grass-dev mailing list
> grass-dev@grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
QGIS is using GRASS HEAD but it should use stable release
of GRAS IMO. The patch should be applied also to 6.2 branch
because it is bugfix.
Do you say that 6.2.1 is useless on Windows?
Radim
On 12/17/06, Markus Neteler <neteler@itc.it> wrote:
To GRASS 6.3-CVS.
Windows fixes.
> Hash: SHA1
> to which branch?
> default?
> pc
> >> Radim
> > Patch applied.
> > Markus
> > _______________________________________________
> Paolo Cavallini
> www.faunalia.it
> iD8DBQFFhYNw/NedwLUzIr4RAlN1AJwJL/5AutK6VRdpR+FkAku2X7t8qwCeM+ny
> rq9Os2h1ZScONhYwbVRyoIA=
> =a6p9
> -----END PGP SIGNATURE-----
Done.
Yes, I think so (at least for the native built).
6.3-CVS is way more advanced.
Radim
>To GRASS 6.3-CVS.
>Windows fixes.
>Markus
>> Hash: SHA1
>> to which branch?
>> default?
>> pc
>> >> Radim
>> > Patch applied.
>> > Markus
>> Paolo Cavallini
>> www.faunalia.it
>> =a6p9
