[GRASS-dev] patch for v.voronoi/v.delaunay
Markus wrote:
> It seems that the precision gets somewhere lost in
> db_convert_column_value_to_string()
> i.e. lib/db/dbmi_base/columnfmt.c
> but I don't find where is is rounded.
Hamish:
lib/db/dbmi_base/valuefmt.c db_convert_value_to_string() does:
        case DB_C_TYPE_DOUBLE:
            sprintf (buf, "%lf",db_get_value_double(value));
            G_trim_decimal(buf);
the %lf is rounding to %.6f?
maybe
- "%lf"
+ "%.14f"
then let G_trim_decimal() remove any extra .00000s.
but maybe such noisy output is not always wanted. :-/
(e.g. pretty output for d.what.vect tcl form)
FWIW v.out.ascii defaults to dp=8.
for the v.colors script, SQL "select * WHERE dbl_col = <FP number>" is
always going to be problematic.
the C way:
if( abs(test - value) < GRASS_EPSILON )
In the case of v.colors, the SQL set loop could be rewritten to avoid
this problem by matching to the cat number, not trying to logically match
the FP value.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
