Hi All,
i’m trying to reproject a vector file in grass6.4.1 from a location “nad 83” to a lonlat location.
nad83 location is using the maryland parameters :
g.proj -p datumtrans=0
PROJ_INFO-------------------------------------------------
proj : ll
datum : nad83
ellps : grs80
no_defs : defined
nadgrids : MD
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
ed
nadgrids : MD
trying to use v.proj i had :
GRASS 6.4.1 (ll):~ > v.proj input=hydrol location=nad83 mapset=PERMANENT output=hidrol
Reprojecting primitives: WARNING: pj_transform() failed: failed to load datum shift file
ERROR: Error in pj_do_transform
i guess it is not able to find the datum shift files, i checked on my system and i found that files here :
i’m on osx the files are :
/Library/Frameworks/PROJ.framework/Versions/4/Resources/proj
i’m on osx lion using grass6.4.1, later today i can try to do the same on a linux machine using 6.4.x | 7.0
i suppose grass is able to find them when i created the location, but v.proj instead fails to load that file.
have you any hints on how to fix this ?
thanks!
Massimo.
