[GRASS-dev] Planning 8.2.0
TLDR: 8.2.0 with GSoC 2021 work (single window, Jupyter, parallel modules) is scheduled for April 5.
Action items: For PRs, merge now or move the milestone to 8.4.0. For issues, create a new PR now or move to 8.4.0.
Dear all,
We are entering a preparation phase for 8.2 release. (As you may or may not know, we are currently skipping odd minor numbers because they are used to make the development version, so there is no 8.1 release.)
On a couple occasions, we discussed that the 8.2 release contains the GSoC 2021 work, i.e., the release will contain Linda’s single window, Caitlin’s grass.jupyter, and Aaron’s parallelized modules.
Unfortunately, I can’t find this in PSC minutes or elsewhere perhaps because the main discussion happened in the Birthday call. We also lack a formalized roadmap, release schedule [1], and release procedure [2] is a draft. However, the current state and plan are well represented in the GitHub milestone [3].
Because 8.2 is a “GSoC 2021” release, the plan is to release it on April 5th before GSoC 2022 starts. Now, it’s time to finish and merge any PRs which are almost done. For PRs which are not ready to be merged, move them to the 8.4.0 milestone. Similarly, for issues, resolve them now or move them to 8.4.0.
Importantly, there is no need for 8.2.0 to contain anything else except what is already on main plus the GSoC 2021 work because the plan is that 8.2 is whatever 8.0 is plus an experimental version of single window, grass.jupyter, and most of the newly parallelized modules.
Best,
Vaclav
[1] https://trac.osgeo.org/grass/wiki/RFC/4_ReleaseProcedure
[2] https://trac.osgeo.org/grass/wiki/Release/Schedule
[3] https://github.com/OSGeo/grass/milestone/8
Here is the current state for 8.0.2 and 8.2.0 milestones:
8.0.2 due: March 31
8.2.0 due: April 05
8.0.2 PRs: 7
8.0.2 issues: 11
8.2.0 PRs: 19
8.2.0 issues: 0
Most of the 11 issues for 8.0.2 are Windows-related. 5 PRs are GSoC 2021 related.
Please, resolve your PRs or move them to 8.4.0.
Let me know if you are interested in having a call about the upcoming releases.
Best,
Vaclav
8.0.2 https://github.com/OSGeo/grass/milestone/15
8.2.0 https://github.com/OSGeo/grass/milestone/8
Dear all,
Best,
Vaclav
Just a reminder for the 8.0.2 release, there are a number of not yet (?) backported fixes:
https://github.com/OSGeo/grass/pulls?q=is%3Apr+is%3Aclosed+label%3Abackport_needed+milestone%3A8.0.2
https://github.com/OSGeo/grass/pulls?q=is%3Apr+is%3Aclosed+label%3Abackport_needed+milestone%3A8.0.1
Nicklas
8.0.2 due: March 31
8.2.0 due: April 05
8.0.2 PRs: 7
8.0.2 issues: 11
8.2.0 PRs: 19
8.2.0 issues: 0
Best,
Vaclav
Dear all,
On a couple occasions, we discussed that the 8.2 release contains the GSoC 2021 work, i.e., the release will contain Linda's single window, Caitlin's grass.jupyter, and Aaron's parallelized modules.
Unfortunately, I can't find this in PSC minutes or elsewhere perhaps because the main discussion happened in the Birthday call. We also lack a formalized roadmap, release schedule [1], and release procedure [2] is a draft. However, the current state and plan are well represented in the GitHub milestone [3].
Because 8.2 is a "GSoC 2021" release, the plan is to release it on April 5th before GSoC 2022 starts. Now, it's time to finish and merge any PRs which are almost done. For PRs which are not ready to be merged, move them to the 8.4.0 milestone. Similarly, for issues, resolve them now or move them to 8.4.0.
Best,
Vaclav
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Dear all,
I have created the release branch for 8.2 series [1] and we are close to releasing version 8.2.0 [2]. RC1 will follow shortly.
As a reminder, 8.2.0 will contain most of the GSoC 2021 work done by Linda, Caitlin, and Aaron (opt-in single window, grass.jupyter, several parallel modules).
Creation of the release branch also means that the main branch is now ready for larger changes.
Best,
Vaclav
[1] https://github.com/OSGeo/grass/tree/releasebranch_8_2
[2] https://github.com/OSGeo/grass/milestone/8
8.0.2 due: March 31
8.2.0 due: April 05
8.0.2 PRs: 7
8.0.2 issues: 11
8.2.0 PRs: 19
8.2.0 issues: 0
Best,
Vaclav
