[GRASS-dev] Planning GRASS GIS 7.0.0 final: a few days left
Hi devs,
according to our
http://trac.osgeo.org/grass/wiki/RFC/4_ReleaseProcedure
the final release is due on 15th of February.
Please check/update
http://trac.osgeo.org/grass/wiki/Grass7Planning#Planningongoing
thanks
On Thu, Feb 12, 2015 at 12:26 AM, Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
according to our
Please check/update
Yes, and let's start a section "Known issues" like any other software does.
Releasing 1 million lines of code bug free does not exist. And we then
have a good reason to prepare 7.0.1 soon.
thanks
wrote:
> Hi devs,
> according to our
> Please check/update
+1
thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
any other open source software does :wink:
Good point!
2015-02-12 0:26 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
Please check/update
I have backported r64499, r64504, r64532 as r64628.
@Anna: Are you planning to backport r64533?
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
On Sat, Feb 14, 2015 at 12:32 PM, Martin Landa <landa.martin@gmail.com>
wrote:
> Please check/update
Yes
Martin
Martin Landa
Hi devs,
according to our
Please check/update
Due to the new blocker bug in the vector libray we are stuck for now.
Hi devs,
according to our
Please check/update
Thanks to Markus Metz the vector library got hopefully fixed - is it
confirmed that the ticket
http://trac.osgeo.org/grass/ticket/2583
is solved?
Can we restart the final release procedure?
2015-02-17 11:58 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
is solved?
I have tested fresh build of G70, it seems to be fixed. Can anyone
else confirm it?
I would say that we can move on. Martin
Martin Landa
On 17/02/15 12:47, Martin Landa wrote:
is solved?
else confirm it?
+1
The remaining critical bugs (are they really critical ?) can go into "Known Issues".
Moritz
On Tue, Feb 17, 2015 at 6:47 AM, Martin Landa <landa.martin@gmail.com>
wrote:
> is solved?
else confirm it?
Please, see today's v.net test:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-02-17-08-00/report_for_nc_spm_08_grass7_nc/vector/v.net/test_v_net/index.html
Can somebody confirm? More comments here:
http://trac.osgeo.org/grass/ticket/2583#comment:29
To run tests yourself, start GRASS session in any Location and then use
python -m grass.gunittest.main --location nc_smp_08_grass7 --location-type
nc
where nc_smp_08_grass7 is GRASS NC SPM Sample location. See details here:
http://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html
Vaclav
Martin Landa
Hi devs,
( http://trac.osgeo.org/grass/wiki/Grass7Planning#Planningongoing )
If no objections, I would prepare the 7.0.0 release on Friday, 20 Feb
2015, likely European evening.
On Wed, Feb 18, 2015 at 8:10 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
Apparently no objections, so in a few hours I'll start the procedure
(btw. it usually takes 3-4 hours with writing up announcements and
such. Native speakers wanted to write a catchy press release!).
