[GRASS-dev] Planning GRASS GIS 7.0.0RC1
Hi devs,
proposal for new RC1 release date: 14 Jan 2015.
Let's please manage to keep that date if you agree.
http://trac.osgeo.org/grass/wiki/Grass7Planning#Planningongoing
On Fri, Jan 2, 2015 at 6:25 AM, Martin Landa <landa.martin@gmail.com> wrote:
2015-01-01 23:55 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
> Also the wxGUI differences I'll leave to the experts :slight_smile:
I would not backport the new and still experimental features like data
catalog. Generally speaking I would leave wxGUI as it is. After RC1
only bugfixes.
Any idea about the difference in gcmd.py in trunk, it's something about
Windows shell escaping? I don't know how to try it out, to understand if we
want it or not.
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/gcmd.py#L163
Anna.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
grass-dev mailing list
grass-dev@lists.osgeo.org
HI,
2015-01-02 22:22 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
I agree. Let's focus on this date. Martin
Martin Landa
2015-01-03 9:49 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
time is running, I would like to kindly ask if there is any progress
in open issues? I can do backport if you confirms which are OK.
Thanks, Martin
Martin Landa
On Jan 6, 2015 11:12 AM, “Martin Landa” <landa.martin@gmail.com> wrote:
Let’s please manage to keep that date if you agree.
I agree. Let’s focus on this date. Martin
Huidae answered yesterday to me. I have added them to the trac page with rev numbers.
For the others no answer yet.
Thanks
Thanks, Martin
Martin Landa
On 06/01/15 11:12, Martin Landa wrote:
Sorry, no progress on my side, but a new issue I stumbled upon yesterday: https://trac.osgeo.org/grass/ticket/2533.
Can anyone confirm this ?
Moritz
Hi devs,
I have now also completed the lib/ tree comparison, done the obvious
backports and identified some differences where I cannot say if to
backport or not:
Kindly extracted with revision numbers...:
Please check! (strike there what's done)
The 14 Jan 2015 is getting close.
thanks,
Hi devs,
...the TODO list got much shorter!
Relevant differences - to be clarified:
* lib/db/dbmi_base/connect.c
* lib/gis/strings.c G_chop() (Markus Metz) r63308
* Change handling of display frame, graphical clip window (Glynn)
(r62026 + r62036)
* lib/python/script/core.py (martinl) r63528
* db.connect substitute variables for database name (-cpd) (martinl) r59671
* r.spread (Vaclav) r63777
* checks for Vect_open_* return value to avoid potential segmentation
fault: r60054 <<-- wasn't the idea to avoid these ugly tests in G7?
Please check those,
I backported this one before the original RC1 release date. I don't know
how it got to wiki, cleaned now. Now I backported also r60922 which is
probably a feature but since it is in trunk for some time and won't be
probably tested better, I just backported it.
Vaclav
[1] http://trac.osgeo.org/grass/changeset/63777
[2] http://trac.osgeo.org/grass/changeset/63820
[3] http://trac.osgeo.org/grass/changeset/60922
[4] http://trac.osgeo.org/grass/changeset/63820
[5] http://lists.osgeo.org/pipermail/grass-dev/2015-January/072736.html
On Sat, Jan 10, 2015 at 11:50 AM, Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
The Vect_open_* return the open level when opening existing maps, not
just success or failure. Some modules, most importantly v.info, try to
open a map first with topology, if that fails, without topology.
Therefore it is up to the modules to decide if the return code is ok
or not.
Markus M
On Mon, Jan 12, 2015 at 10:02 AM, Markus Metz
or not.
ok, backported in r64075.
Also backported v.to.rast: (replace custom cell type with raster cell
type; use size_t) and a few other things.
Actual state:
To be clarified:
- v.distance: geodesic support
- v.kernel: Vect_net_shortest_path_coor2() usage
- v.out.ascii: return test in vector/v.out.ascii/main.c
- v.select: various differences
or not.
Actual state:
To be clarified:
backported in r64094,5
The API changed in G 7.1 because of new turntable support in network analysis.
backported in r64096
code optimization, no bug fix
Markus M
On Mon, Jan 12, 2015 at 3:20 PM, Markus Metz
Just to understand: yet not tested enough to be backported?
markusN
Optimizations are not high on my priority list of backports. You
tested v.select yourself: the GRASS-internal overlap operator vs. the
GEOS overlaps operator of v.select, in order to select tile coverage
from buffered linear features. The GRASS-internal overlap operator is
more accurate, and processing is faster (after optimization).
Markus M
On Fri, Jan 2, 2015 at 10:22 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
The RC1 release is due today :slight_smile:
The planning list is looking good to me. And it is not the final but
RC1 release.
If there are no objections, I'll tag later today.
Hi Markus,
2015-01-14 9:29 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
RC1 release.
no objections here. Martin
Martin Landa
Hi devs,
RC1 release.
Go for it !
Moritz
+1 Markus !
On 14 January 2015 at 14:19, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi devs,
RC1 release.
If there are no objections, I’ll tag later today.
Go for it !
Moritz
... tagging now .... RC1
Done!
http://trac.osgeo.org/grass/wiki/Release/7.0.0RC1-News
Now time to announce it...
