export GRASS_PNGFILE=/tmp/pokus.png
export GRASS_RENDER_IMMEDIATE=TRUE
time d.vect map=soils@PERMANENT
real 0m0.197s
user 0m0.166s
sys 0m0.019s
time d.vect map=soils@PERMANENT color=yellow fcolor=yellow cats=32 width=3
real 0m13.767s
user 0m13.611s
sys 0m0.098s
Why is the second case so slow? Is it a bug in PNG driver? What can I
do, so it is rendered faster?
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
real 0m0.197s
user 0m0.166s
sys 0m0.019s
real 0m13.767s
user 0m13.611s
sys 0m0.098s
My guess is the width=3.
The "thick line" code in the PNG driver is a truly awful hack (see
store_xy() in lib/pngdriver/Draw_line.c).
> real 0m0.197s
> user 0m0.166s
> sys 0m0.019s
> real 0m13.767s
> user 0m13.611s
> sys 0m0.098s
I've replaced this with a more reasonable implementation.
However, note that the PNG driver doesn't have a proper polyline
implementation; it just draws each segment as a separate line. This is
fine for single-pixel lines, but for thicker lines the lack of proper
joins may be noticeable.
Thanks, Glynn, I just used it in new GUI function - you select objects
in attribute table and they are displayed with d.vect col=yellow
width=3 in map display..
It works great, thanks again!
jachym
2007/4/6, Glynn Clements <glynn@gclements.plus.com>:
> > real 0m0.197s
> > user 0m0.166s
> > sys 0m0.019s
> > real 0m13.767s
> > user 0m13.611s
> > sys 0m0.098s
Jachym Cepicky
