porting to grass7 i.spec.sam (grass-addons/grass7/imagery/)
I am getting a set of complaints like this:
OBJ.x86_64-unknown-linux-gnu/spec_angle.o:(.bss+0x158): multiple definition of `Avector’
OBJ.x86_64-unknown-linux-gnu/main.o:/home/yann/dev/grass-addons/grass7/imagery/i.spec.sam/main.c:92: first defined here
while it is actually defined in global.h, and global.h is read in main.c as well as in spectral_angle.c . The line 92 in main.c is the first appearance, without declaring Avector (just using it).
On Mon, Jan 19, 2015 at 11:31 AM, Yann Chemin <ychemin@gmail.com> wrote:
while it is actually defined in global.h, and global.h is read in main.c as well as in spectral_angle.c . The line 92 in main.c is the first appearance, without declaring Avector (just using it).>
On Mon, Jan 19, 2015 at 5:31 PM, Yann Chemin <ychemin@gmail.com> wrote:
of `Avector'
first defined here
of `Avector’
first defined here
(the mail from my mobile isn't yet here, so I try again)
On Mon, Jan 19, 2015 at 7:13 PM, Yann Chemin <ychemin@gmail.com> wrote:
Seems to be the last hurdle..
ogr_api.h
In file included from
/home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vect/digit.h:3:0,
from
/home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vector.h:4,
from main.c:27:
/home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vect/dig_structs.h:27:21:
fatal error: ogr_api.h: No such file or directory #include <ogr_api.h>
compilation terminated.
In file included from /home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vect/digit.h:3:0,
from /home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vector.h:4,
from main.c:27:
/home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vect/dig_structs.h:27:21: fatal error: ogr_api.h: No such file or directory #include <ogr_api.h>
of `Avector’
first defined here
